Topic: Got a question about engine codes and other general questions. (Read 9753 times) previous topic - next topic
Reply #75
I had a Carter replacement pump fail after less than two years, just quit wouldn't run at all(well to be exact, it ran when it felt like it)... That was back in '01, replaced it with a Walbro, still fine...
Reply #76
I had heard good things about walbro.... So I bought one.... We'll see.. Now if I can get the digital gas gauge to stop playing games with me... I'll be fine... I'll change the fuel filter tomorrow... I wanted the filter to trap the sedement from the tank b-4 I changed it...
ǾĐÍξ
Reply #77
Well it's been over two weeks, since I installed the new fuel pump... So far So Good... I waited til last week to change the fuel filter...I wanted to get as much sediment out of the tank as I could... It still has the feeling like something is binding up.. But, it's not stalling out like it was at WOT...  There is a slight hesitation in the throttle somewhere... At cruising speed..lower rpm range.. and lightly on the pedal.. an 1/8 or so.. It'll start bucking .... When I mash down on the throttle it goes away? Any Ideas? It seams to do it worse just after the car is started... after you drive a few miles it quits acting up....
ǾĐÍξ
