Topic: 3G alternator swap (Read 3609 times) previous topic - next topic
3G alternator swap
I would use a set of jumper cables ran together. You can pick them up for around $20 usually, and there around 6 gauge.
Umm.........
Quote from: vinnietbird;276510
Well worth it,and doesn't take much time or money.I got my 3G from a 3.0 Taurus for cheap,polished it,and after 3 years,still going strong.
What year 3.0 Taurus and was it a Duratech?
2003 Marauder 300B
1996-97 Cobra wheel straight but weathered (For Sale)
84 TC manual shifter handle no  (For Sale)
BTW, I had a 1988 T-Bird Sport way back when. I found out that it was totalled shortly after trading it in. It still has the ignition switch recall to date.
Special thanx to EricCoolCats for showing me to this site.:bowdown:
3G alternator swap
Just a standard 3.0.It was a 90 something.
3G alternator swap
Quote from: vinnietbird;280905
Thanx for letting me know. This might help in the future.
2003 Marauder 300B
3G alternator swap
I always kep a couple of extra alternators in the garage as a just in case.
3G alternator swap
Granted they're $150, but I like the 95A 3G from PA Performance. No bracket mods and I used the original wiring, just changed the connectors to the ones provided with the alternator. 64 A at high idle is more than enough - I see 14V typically. They're guaranteed for life too.
For $40 more you can get it powder coated in a bunch of colors too http://www.jdsperformance.com/index.asp?initemuid=539&fcmd=item&inmake=0
Just out of curiousity...
Quote from: vinnietbird;280965
How many extra alternators do you have?
2003 Marauder 300B
3G alternator swap
Does it matter where in the charge wire, you put the fuse?  Meaning, distance far or nearer the alternator/battery?
Mike
