Topic: heater core nightmares...FINISHED!!! (Read 4323 times) previous topic - next topic
I did mine without dicharging the A/C, you actually DON'T have to get the A/C discharged...  I just wish I could find the instructions I used...
Willpower is no match for Horsepower.
Quote from: David
you dont?  wish I would of known that before :flip: but everything is good A/C is still cold.  anyone use Redtek 12a in their A/C?
Well, the nightmare is over. It took about 2 and a half hours. CoolCats was instrumental in getting the job done with minimal heartache. I had both my Chiltons and Haynes manuals out and ready, but they were little to no help at all. The only problem I had was that the bolts that hold the A/C accumulator to the firewall are also the same bolts that the heater core box is attached to. There are technically 5 bolts that hold the heater core box in the car. I want to thank Eric and all the contributors to the technical article on CoolCats. I also want to thank Ford for giving me the correct part, because I would be so  pissed if it was the wrong one after going through that!  Someone mentioned it was a "right of passage" for owning one of these cars. Can I learn the secret handshake now? :giggle: :hick:
