Topic: 1988 TC single Holset turbo 5.0/ 4R70W (Read 372706 times) previous topic - next topic
Reply #165
Spent some time re-forming the oil dipstick. I'll need to fool around once the header is on to get the hold-down to fit right.
Mounted the FPR and started making the hoses. Just 1 more fitting to assemble on it now, and put in the plugs on the regulator. Then I can paint the bracket and tighten everything down.
X
X
X
Reply #166
Stuck on the silicone to check the angles. It's gonna work OK I think!
X
X
X
Reply #167
What color should I paint the intake tube? Black, silver, blue? I'm not going with any red except the fittings.
I'm leaning toward silver, myself.
Reply #168
Silver is definitely the color I would paint it.
flylear, did you wire up your Gentex mirror sensors?  What did that entail?  What model mirror did you get?
Thanks, keep up the great work!
Reply #169
SILVER.
Been following. Can't wait to see it running. Looks like your finally getting close.:D
Reply #170
Quote from: The Shredder;352565
Thanks for the input. I think keeping it silver will look pretty good. It's not a 'show bay' but I want it to look nice.
Here's the bay on the TR7 from photobucket:
And another with the Tbird in the background.
X
The Gentex is a GEN-177 from a Chevy Silverado. It has autodim, autodim cancel on backup, temp readout and built in compass. The Ebay harness never showed up, so I made my own. Here's the documentation I used:
X
I just bought a used temp sensor and pigtail off Ebay and ran wires for it. Nothing else is installed yet.
Reply #171
Quote from: sarjxxx;352568
SILVER.
Yeah, silver.
Closer every day!
 I got the Ranger condenser in hand last night. I'll fiddle with that this morning. (Slept in until 8:00). I like the outlets on opposite sides of the rad for less AC hose, but the outlets will most certainly need to be re-bent to clear the IC outlets.
X
X
X
I think I got it!
Reply #172
OK, got down to it and think it's a go.
1. I removed all the brackets and braces from the top of the new condenser.
2. Bent the #8 line up and over the top of the core.
3. Put a bender on the #6 line and curled it down under the IC inlet.
4. bent the top IC brackets more forward to clearance the top of the radiator a bit and allow the condenser more room at the top.
5. Add 1/4" rubber spacers to the bottom of the IC
6. make new bottom mounts for radiator pins out of light angle, spacing in toward engine about 1/2"
7. Add rubber spacers to radiator top mount, or possibly make new brackets on top to allow rad to drop 1/4". Not sure on that, but I'm going to try to finish it all up tonight.XXX
Reply #173
How the new bend and the pipe mod work on the #8 line.
X
The IC more upright and a bit forward from before.
X
The new stack
X
Reply #174
Looks like it will work to me.
(Man, I wish I had a bigger garage, so I could make some decent headway over the winter.)
Reply #175
Quote from: Chuck W;352628
Yeah, the garage pretty much kicks ass. 32x40, finished, with a ton of lights, cable TV and ethernet. No bathroom, but running cold water.
I sold my Porsche to build this sucker when I was about your age! It's something I don't regret, even though it costs to keep the heat on and extra money on the electric bill.
Even though I loved the 951, this thing was worth the trade.
Reply #176
Powder coat silver.
Reply #177
Nicely done, the new setup looks great.
Reply #178
Thanks, Bruce!  I have a HF powder coat setup here I never got out of the box. Maybe after I get this done I'll go back and do things over in powdercoat. It seems like we all like the silver!
The day ended with the rad mounts welded on the bottom, and the condenser lower mount pads in place. I used the old top rubber from the TC rad hold-downs trimmed down a bit for that. I then used some round rubber Triumph TR6 radiator pads on the lower pin pads, worked great! (I've got a -ton of old Triumph stuff around here).
Ran out of steam before I got the condenser top mountings made, and still have to make and weld on new top radiator mount brackets. They are going to be straight-forward bits, pretty simple. I am finally happy with this setup, though.
I have Med-Air CPR/AED/ First aid training tomorrow, so not sure if I'll be able to get this finished Saturday or not. Before it gets screwed down the last time I'll be cleaning and painting the IC. I'm tired of looking at it all crusty.
The real downside to this configuration is the loss of area on the condenser. I may see the AC unable to keep up on really hot days. It's a sacrifice I'm willing to make, I guess, in order to get the IC I want.
Reply #179
OK, all done with the mounting, and here are the final pics of the results.
Braces on the #6 AC pipes and the rad mounts
X
X
X
