Topic: Fuel pump issues (Read 3056 times) previous topic - next topic
Fuel pump issues
Actually the problem is, we're are directing this to someone who has no trouble shooting experience... Change enough parts and about any problem can be solved...
Fuel pump issues
I wonder if she could make it happen by washing the car,,,,
ie- wet down the trunk area first and wait
then wet down the hood area / windshield and wait.
that might help her to pin point.
Fuel pump issues
The pump does run it's normal 2 or 3 seconds and shut off. No key in the ignition and when it's damp out.
Karl's been having this issue since he got it but didn't get a chance to find out what was causing it.
I am not familiar with some of the stuff you guys are talking about, and Roger isn't really clear on some of it... but I told him how to get to the relay and to tap it to see what happens...so we'll start there.  I can let you know what he finds and go from there.
I really appreciate all of the help.
:cougarsmily:~Karen~
Fuel pump issues
LittleAngel1198, if you are ever roaming thru the lower portion of the county(Busti to be exact) with the car look me up and I will see if I can help you out.
Fuel pump issues
Quote from: EricCoolCats;272768
As mentioned, it's likely either the ignition switch or the fuel pump relay in the trunk. I'd lean more toward the latter. Moisture and/or cold weather can start messing with that relay (and the inertia switch, for that matter). I've had that happen several times throughout the last two decades. Besides, if I know Karl, he probably already changed the ignition switch...not that that would guarantee anything, but it's doubtful the fuel pump relay was ever changed before.
Eric is right, I already changed the ignition switch.  Here's my old thread about this issue and some of what I did to troubleshoot:
http://www.foxtbirdcougarforums.com/showthread.php?t=8421
Fuel pump issues
Thanks Karls...that saves us some searching.... I should have looked for that.
Fuel pump issues
Ok, so Roger did the test with the relay and it was fine.
I guess we'll keep looking.
