Topic: 5sp vibration (Read 3169 times) previous topic - next topic
5sp vibration
Since I have done the 5speed conversion, I have a vibration. I had used my stock aod driveshaft. I have changed driveshafts and still have a vibration. Is the tranny mount the sames for the aod & 5speed? Is it possible that the bushings in the rear control arms are bad enough to give this vibration? If someone else who done the 5speed conversion had this problem, what did you do to get rid of the vibration? Your help will be greatly appreciated.
Our web page
02 Explorer XLT 4.0L
04 F150 FX4 Supercrew 5.4L
02 Saturn SL1 1.9L
09 Vstar 950 Tourer
Re: 5sp vibration
no vibration on mine.
did you try rotating the driveshaft 180 degrees? supposedly they are balanced at the factory. i reused the aod mount, doublehump crossmember and driveshaft.
what kind of vibration are you getting...only at certain speeds? or just reving the engine with the car not moving?
what tranny did you use? and what piolot bearing did you use?
~John~
Re: 5sp vibration
Quote from: 1badcougar
I've had issues on and off after the Tremec conversion - or was it when I went to 3.73's? Anyway, one thing that helped was getting a new tranny mount - the old one was oily and messed up. I got a nice balanced driveshaft - that helped a little. I'm OK now up to like 75 MPH or so - though it isn't real bad up to track speeds of 110 MPH. Good motor and tranny mounts help make sure the drivetrain is aligned. Doing the driveshaft clocking (mounting it in all four possible positions and driving it) helps get it fine tuned too.
Re: 5sp vibration
Is your car lowered any?  Sometimes the pinion angle can be off enough to cause a vibration.  Other than the the above suggestions should help.
Re: 5sp vibration
well, its also possible he used a 4 cyl tranny with the wrong piolot bearing. its been known to cause a vibration.
~John~
Re: 5sp vibration
How is the transmission? What condition was it in when you put it in? Vibration could possibly be in the Trans, and does it have enough oil?
1986 bird, 306, Dart heads, 550 lift cam, exp. intake, 50lbs injectors, 76mm C&L MAF, Procharger D1R blower 14lbs, 3 core intercooler, 55shot ZEX N20, tremec 5speed, 3.73 gears, auburn pro posi,headman full length headers, 3" exhaust
custom chip by 5.8FastCat
[SIGPIC][/SIGPIC]1955 bird 351w, AFR 185 Heads, 580 lift cam, D1R  Procharger 10lbs tremec 5speed, 3.92 Gears
2007 Hayabusa, R-22 pipes, K&N,  Power Commander
192hp
"Imports are like tampons, every p@$$y has one"
Re: 5sp vibration
I have fixed my vibration last night. I was working on rotating the driveshaft 90 degrees and seen the u-joint had some play in it. I have replaced the u-joint and knocked the balancer ring off the tranny yoke. Installed the driveshaft by rotating it 90 degrees from where I had it installed. Took the car for a ride and didn't have a vibration. If I now have any vibration, it is very minor that I haven't noticed. I really appreciate all your help.
Our web page
02 Saturn SL1 1.9L
09 Vstar 950 Tourer
Re: 5sp vibration
awesome...im glad it was something simple bro..
~John~
