Topic: how do you remove window trim (Read 872 times) previous topic - next topic
I bought one of those fancy tools to remove the front and rear window trim but does anyone know how you are supposed to use it?
How do the clips release?
If you are talking about one of those Y shaped tools then you use the end part to snag the clip and pull it away from the body then lift the trim up.  Hard to say it and get the right Idea. Hope that helps though
Stuckman
Just start prying around gently and youll see what Stuckman is talking about. DONT BEND THE CLIPS! Thats the only advice I really have. When I did it I was just tearing stuff up to see how it worked since most of it was trashed.
