Topic: Evolution II.....SEFI upgrade ..... updated 10-23-2015 (Read 228079 times) previous topic - next topic
Reply #315
Quote from: thunderjet302;451907
You'll have it done just in time to put it away for the winter ;).
at this rate, I'll have it done in time to take it out next April. :hick:
Reply #316
so far it looks like it may be a wiring nightmare
Reply #317
Jerry, I saw the fog light covers (NOS) on ebay for $65 buy it now....shipped. That's cheap. Also, your bracket has been shipped.
Reply #318
may be looking for the front wiring harness, the harness that goes into the drivers side firewall, and the AC compressor wiring harness to make this work... they would have to be for an 86 5.0
Reply #319
I'm Back.....
After a year or so of figuring out the best way to tackle my EFI upgrade, I decided to install harnesses from an 87. Dash and engine bay....
There was way to many incompatibilities with an 85 dash harness and an 86 computer harness. Not to mention the front headlight wiring nightmare that has the old wiring that connected to the battery located on the pass side of the car.The next idea was using an 87 dash harness with an 86 computer harness.... Still a bad idea. They also don't connect together without a lot of re-wiring, and re-pinning. and the connectors are also diff between the 2. After looking at wiring diagrams for months, Mustangs included (which were closer to an 87 computer harness), I decided the only way to do this painlessly, and be able to troubleshoot future problems, was to start from scratch so to speak... So everything is now getting upgraded to an 87 in the vert. I also have parts that I can now swap between the 2 cars going this route, so in the end it was a no brainer. Today I stripped the dash and wiring out. And so begins the rest of the storyX
Reply #320
Im about ready to part out my 86 cougar, lots of miles, but ran like a top. Id imagine the 86 stuff would be easier....
Reply #321
Quote from: Haystack;459079
probably the same as what I'm doing with the 87 stuff
Reply #322
Yeah, but the headlights and dash should be the same harness.
The 85-86 cars they only ran the wires needed, the 87-88 cars there are a ton more connectors and wiring to make adding options easier.
Let me know if you need anything.
Reply #323
has anyone replaced the dash harness before? is attaching it to the dash frame, and re-installing the dash the best way to go about this procedure?
Reply #324
That's the way I did mine. Best advice to give is to mount it "loosely" to the connecting points. I used zip ties that weren't quite snug the last time...so if I need to tug on a bundle an inch or so..I could.
My regret is being EVTM-illiterate, else I'd probably still be playing with the sport.
Reply #325
What tires & wheels, offset you have mounted on the convertible. Those look nice and beefy in the back. I would like to install the fattest that can fit under the wells and then give it a nascar kind of look with the rims and wide white lettering and maybe a little lowering.
1985 Muscle Car V8 Thunderbird
tbirdregistry.com - #56919
Lorain, OH. Assembly #151041
811 TBirds followed Mine
1988 Thunderbird V6
tbirdregistry.com - #80084
Lorain, OH. Assembly #111106
