Topic: 70 mm maf (Read 1459 times) previous topic - next topic
70 mm maf
What cars are they pulling these 70MM MAF's out of?  They claim to bolt in the same as the Mustang piece and callibrated for 19lb injectors.
Mike
70 mm maf
A MAF from a 94-95 Mustang GT or 92 1/2-94 Crown Vic will work if you make it hook up.
I used a 95 Mustang GT sensor in a '93 Cobra housing since all the critical dimensions were the same, and it mounts in place of the old one.
Matt
70 mm maf
also the V-8 Later model T-Birds and Cougars (90's models).
70 mm maf
Quote from: 5.0 bird;269683
In addition the housing from a 94-95 3.8 or 4.6 T-bird/Cougar is the same as well. You can take the sensor from the 92-94 Crown Vic, Grand Marq, Town Car, or 94-95 Mustang 3.8 or 5.0 and use in the 94-95 T-bird/Cougar housing. That's what I'm doing and I have no codes because off it. Make sure you use the sensor that starts with F2VF.
70 mm maf
Yea, but I feel that is over priced.  I just bought one last week from the pick n pull for $30 with a 6mo warranty. Mine was from a 94 Continental I believe.
70 mm maf
Quote from: vinnietbird;269706
You mean the ones with the 4.6's?
Mike
70 mm maf
Quote from: mcb82gt;269829
Any 94-95 T-bird/Cougar has the housing you need. 3.8 and 4.6 cars shared the same MAF. Just use the sensor (the black thing on top with the plug) from a 92-94 Crown Vic, Grand Marq, Town Car, or 94-95 Mustang 3.8 or 5.0 and stick it in the T-bird/Cougar housing.
70 mm maf
Should I grab a mounting bracket off the t-bird/cougar?  Or should I get a stock Mustang one?
Mike
70 mm maf
The stock Mustang bracket will be fine.I don't even use a bracket and the thing doesn't move.
70 mm maf
Yep use the stock Mustang bracket. The T-birds/Cougars mount the MAF to the air box lid.
