Topic: C5 fluid discontinued? (Read 3259 times) previous topic - next topic
i need to add oil to my c5 trans and looked up in haynes manual to find that i need to put type H fluid i went to the store and it appears there is none, i also cheked on motomaster.com and they dont seem to have type H fluid is it discontinued or what and if so what can i put in my c5 thanks everyone
You won't find it. they say you can use mercon or mercon V.
Dexron II = Type H. I don't know if you can still find Dexron II, but Dexron III or IV should work. DON'T use Dexron V!
Here's a link about trans fluid. don't know how reliable it is.
http://www.aa1car.com/library/atf.htm
From the 84 shop manual:
C3 and AOD use Dexron II
C5 use type H.
"The fluid used in C5 A/T contains a detergent that retains particles in suspension that are generated during normal transmission use."
You are right, Type H is no longer available. Mercon replaces it.
I posted the info from the shop manual incase someone was curious about the difference between Dexron II and Type H.
I would use Dexron II, Mercon or Mercon V.
But I'm no trans expert. If they say one replaces the other, I believe them.
i just use type f transmission fluid it works too.
i use water in mine. lol:mullet:
john deer ftw.
it hasnt been available around here for some time. i use dexron-III since its cheap, i dont like the way the car shifts cold from it though(too snappy for my taste)
I use fresh carrion blood.
then this should be fine i guess  Mobil Multi-Vehicle ATF  is approved for mercon v
also can i just add it to whats in the tranny already or 2 different brands of oil cant mix  wich i doubt
Type f usually provides the snappiest shifts but Mercon will work fine.Mercon V i a synthetic i believe and a no-no in a used unit.
Pimp smacking smart azzes on the streets since 1970
