Topic: maybe too much oversteer .. options? (Read 3389 times) previous topic - next topic
these might help. they are the best i have on hand.
here you can see the mounting point for the inner tie rod end. notice the seam, and the new material that has been added to the lower portion
and here you can see the heim, spacer stack above the heim, and the new tie rod.
MM offers a height adjustable outer that can help, but AFAIK KB was the only one to offer the modifications to the inner pick up point.
ummb... does t3skidoo have an IRS too???
http://foxtbirdcougarforums.com/showthread.php?t=19556
You miss stuff when your not around.
While I don't know much about the IRS, you talked about your front droop.
Do you have camber/caster plates yet? The Maximum Motorsports plates gives you spacers to where you can move the strut up and down in relation to the plates. While it may not be much, it could be something that would help with your front droop.
Either way, they wont hurt.
I really used to look forward to your threads. I really liked dark thunder. When I first joined in the ezboard days, you and Dare used to make my day.
Responses to posts -
Mods (that I can remember)
Front - CC plates, 'long' control arms - relocated inboard ~.3/4", SN95 spindles, brakes, (Koni single adj) struts, coil-overs, MN12 inner/outer tie rods.
Rear - IRS, MM bushings and a/s end links, coil-overs, bilsteins w/ extensions
Yoko AVS on 18x9s all around, 265-35s on +12 offset /275-35s on +40 offset
1) The alignment shop didn't check rear bump steer when they aligned the car.
2) There's more room between the strut and tire than I previously thought, so front suspension travel is fixed now, and the ride seems to be better - will know after I get it aligned next time.
3) another thought occurred, first time at the track, there was just a touch of oversteer.  later, there seemed to be more. The only real change was tire wear, the fronts are worn much more than the rears.  I'm wondering if increased front grip isn't causing the rear to seem loose?
__________________
Twin '85 TCs
White/ Grey 2-tone
I REALLY hope your having your alignment done by a shop who knows how to set up for road racing and not just joe shmoe's tire shack...lol.  Can you post up pics of the front tire wear you were talking about?  Anything irregular about the wear pattern?  Also, what were your alignment angles set to during your last alignment?
Good luck,
Don
The alignment shop regularly does a/x and road race cars.  That said, it does look like they could have put a bit more neg camber in the front.
Tires - check here
Inner links question - Is it as "simple" as getting a longer link or does there need to be a different mounting point?
__________________
Twin '85 TCs
White/ Grey 2-tone
