Topic: box of goodies (Read 4427 times) previous topic - next topic
box of goodies
Quote from: mercury-man;265537
DVP, I'm with you also on that box of goodies....but can you build me a place to store it too ?? :evilgrin:
How big do you want it?
box of goodies
Quote from: EricCoolCats;265450
Very nice, Scott! Quite the stash.
Could you get the part number from the grille for me, please?
E7WB-8150-BB
google yields nothing when searched.
box of goodies
Those broken pieces.....they shoulda been yellow like the tops of the side marker bulb screw in......I beleive something may have broken:punchballs:
FOXLESS!!
1994 Lincoln Mark VIII
box of goodies
Quote from: 20thanniver-ls;265547
glue,, im not cryin.
box of goodies
Quote from: jcassity;265541
BTW, i am attempting to replace the front arm rest cover using a rear armrest cover........any thoughts?
I've done just that - it's so nice when you first set your arm on what is essentially virgin leather :D
BTW, it makes for a shorter armrest, which in my case was exactly what I wanted since the original didn't allow me to comfortably rest my hand on the shifter while cruising (half the reason I switched to a manual gearbox :) )
box of goodies
Quote from: Cougar5.0;265564
it works?
box of goodies
Quote from: jcassity;265566
it works?
Yeah, I forget what finagling I had to do to make it fit, but in the end it looks OEM - only someone in the back seat might be able to tell it's not - I'll get some pics f you'd like. Note my additional comments I edited to my post about how it makes the armrest shorter (which was good in my case).
box of goodies
Wow are those things dirty.....with all that dirt removed they may look ok!
FOXLESS!!
box of goodies
have them hanging up to dry (on the wifes good hangers:evilgrin: )
Laudry mat might steam clean them but im afraid they will shrink to after all this.
I noticed the driver side backing has a tear along the rid pin strip, gotta figure out a way to stop it in its tracks.  stitch witch or maybe a fabric shop can help.
box of goodies
Wow, thirsty? Don't drink the water. Ewwwww
box of goodies
Quote from: jcassity;265544
E7WB-8150-BB
All of my grills have that same part number.
Scott, here's a couple of pictures of the rear armrest made into a front armrest. As you can see, it's just the visibility of the zipper from the back seat that makes it not perfect IMO.
box of goodies
it wont work better if you flip the cover upside down?
It was my thought that fipping it opposite of how it sites in the rear would make it work better up front.
Perhaps the cut out holes stop you from doing this?
box of goodies
Yeah, I don't remember the reason I had to do it this way and if I cut down the bigger padding or what, I did this like 8 years ago. I think it's one of those "obvious if you see it" situations. I can tell you that the zipper is not at all visible to the driver or even at a show (hid by side of seat), so it isn't something I fret about. :)
