Topic: 92 Mark VII ECU ok to do a HO swap into an 88 5.0 T-bird? (Read 2944 times) previous topic - next topic
The A9P (a MAF computer, which I run as well) needs the VSS input to function correctly. A SD computer does not, except for the speed limiter. The nice thing is I didn't have to run VSS wires in my car when I did the MAF swap as the 88 Birds/Cats had the wires from the factory. The 87 and down cars didn't though
Quote from: Cougar5.0;265332
'87 Cougar here - VSS equipped.
+1 here.  Build date 3/17/87
Also remember, the ECU in question from the original post is in fact a  speed density ECU.
Quote from: Kitz Kat;265372
Not sure but I had issues till I hooked it up.87's don't have it.
Like I said it felt like big time valve float, just died and back fired.
Stop shut it off restart no problems. I thought it might of been the ignition switch, same ones still in though. ic you need to wire that if you read this.
Dunno what your problem was, but I ran a A9P in a '86 5 speed stang with no issues and no connection to the speed sensor(the Stang didn't even have one)...  It's the same one I ran in my TC till I got a A9L...
