Topic: Mileage (Read 4856 times) previous topic - next topic
Mileage
538??!?
That's worth quite a bit.
-'88 Tbird 3.8
-2012 Altima 2.5 BASE.
Future: Budget 5.0 300 HP.
Mileage
129,000ish ;)
Mileage
127k
Mileage
Had 225k miles on stock everything (except upper intake) before replacing the motor and transmission, along with soon all suspension and rearend. Then it will be back to the less important things (re-repaint and reupholstery). Have 23x,xxx now on the body.
1988 Thunderbird Sport
Mileage
One of the things I like about my car is that its been around the block a few times!  It is showing around 185,000 miles now.  My car is still on the original engine and transmission that have never been touched really.  Swapped rearends at around 183,000.  There was nothing wrong with the 7.5 and I still have it, just wanted a TC rear.  Only things i've changed other than routine maintenance are timing chain (only reason I changed it was I f'ed the orig. timing cover when changing a water pump and figured I might as well change it while I was in there), several fuel pumps, and a couple of motor mounts.  It even has the original cap and rotor still, although that will change soon.
Mileage
Transmission #2, Engine #3, Paint job #3, Exhaust system#3, Heater core #3, Original driveshaft & rear axle housing (but not gears, axles or locker :hick:)
Mileage
around 109,000 on my 87
Mileage
Transmission #2, Engine #3, Paint job #3, Exhaust system#3, Heater core #3, Original driveshaft & rear axle housing (but not gears, axles or locker )
, sounds like your rig has been through some different combo's over the years!
How could I forget I did put a new heater core in my car too...I think I must have blocked it out of my memory since it was such a traumatic experience.  It also did get new exhaust once.:D
O.o
:mullet: Idk if anybody else's car did this, but when my car was at 199,999 miles, and it went to 200,000, the odometer read "100,000", instead of 200,000.
Anybody else had that problem?
-'88 Tbird 3.8
Mileage
Quote from: RunninWild;265474
normal
Mileage
85k 86 Cougar LS 5.0
Had 54ish when I got it 4 1/2 years ago. Was a real clean car then. Havent had to do any major maintenance til this point. Now Im doing almost everything on the front suspension.
Mileage
83 Heritage....160k
83 Gray 460 T-Bird...149k
84  T-Bird....112k
87 TC 460....146k
87 Black TC 67k
83 T-Bird 460
83 T-Bird Heritage 5.0
84 T-Bird 5.0
87 T-Bird Turbo Coupe
88 Bronco II Drag truck 302
95 Mustang GT auto
2004 F-350 CC Dually V-10
Mileage
88 xr7- 137k----ihear ya on the suspension dvp!!!!
88Ls- 158k
[/IMG]
Just enjoyin the ride!!!!
Mileage
its in my sig....  and I update it every week with the new milage.
Mileage
I've got a suspension problem too..
The front end creaks really bad when I turn the wheel in reverse.
-'88 Tbird 3.8
