Topic: it! (paint frustrations) (Read 2917 times) previous topic - next topic
I used the same as andrew on my freinds toyota. They wear out quick, but they get down to the metal just as fast as anything else we tried.
flexible or semi-rigid blocks are $10 or less. :)
1987 TC
Yea they do wear out fairly quick but theres no chemical mess to clean up or to worry about wrecking new paint. I think I used about 15 of them on the whole car and a about a weeks worth of evenings to get all the paint off. 40 grit on the orbital sander works pretty good too.
I just used my grinder and a 40 grit disk. you can strip an entire car in about an 8 hr. day. If you use a grinder, you have to keep the speed around 1000 rpms, or you'll distort the panels from heat buildup.
What Rcarder407 has is what i have been using for a loooooong time, I've been painting for about a year and a half.
DAs are great for small areas, but for anything like an entire panel, expect it to take a long time to strip. But it can be done.
I, for one, like the idea of soda blasting.  Followed by Hold Tight 102
1987 TC
Where do you get them for 10 bucks?????????????? im only taking all the scratches and dings out of the body,and sanding off the clear, but i will need a block for my pass. door.....
[/IMG]
Just enjoyin the ride!!!!
oh, i thought you were taliking about the longer ones that you attach sandpaper to......those look good tho......
[/IMG]
No matter the size of the board, people still tend to push the distance their arm allows.  Which is about 2 feet.
Also, the trick with the softer blocks is hand pressure.  Don't want to be heavy with the fingers.
1987 TC
right, im constantly sanding the area lightly, then gliding my hand over it lightly to see if i can feel any imperfections, but i still need blocks, and some more fine sandpaper......
[/IMG]
Pneumatic rol-lock grinder.
game over.
Quote from: 87thunderbirdBlackJack;263346
game over.
Ah ha!
Body guys at the shop I work at use 'em all the time... couldn't remember what they were.
Quote from: Ifixyawata;263362
Ah ha!
I use them everyday too.  running a 3" will take awhile, but it is effective.  Just gotta be careful of scratches...may end up more work in the end.  My $.02  I have MAC for the roloc, and I have a Ingersoll Rand  with 4.5" sanding discs layed back to back instead of a backing pad, and they work fast as well, but again, sanding scratches.
Bristle discs work pretty good too, but they'll wear.
1987 TC
