Topic: Tranny problem?? (Read 1995 times) previous topic - next topic
Tranny problem??
I have been thinking of buying this 95 t bird,(I know, not a fox:mad: ) and the guy says the tranny will shift fine in 1st and 2nd, but in 3rd it will just rev up. Anybody got a ballpark idea as to what it could be?
FOXLESS!!
1994 Lincoln Mark VIII
Tranny problem??
According to Baumann http://www.becontrols.com/ourfaqs/aodetroubleshoot_1.htm , that AODE probably has some burned out clutch packs. If it simply wouldnt shift out of 2nd then it could be a minor problem....but if it...."shifts OUT" of 2nd, and jsut free revs without moving the car at all...sounds like some stuff is roached.
Tranny problem??
Slipping in any transmission is a bad sign. Usually does not lead to an easy fix. Keep in mind. Its not always the TV cable....
Brian
Tranny problem??
So basicially a tranny rebuild/replace
FOXLESS!!
Tranny problem??
Count on nothing less. You could always try the tranny miracle oil. I have heard that is a good temp fix sometimes. You never know.
Brian
Tranny problem??
Yea, It's always worth a try first lol
FOXLESS!!
Tranny problem??
On a 95  it could be a bad solenoid, Probably not though.
Tranny problem??
Yea, that would be too easy....
FOXLESS!!
Tranny problem??
Had a buddy that had one, nothing but trouble. Sits in the lot behind his house now.
Tranny problem??
Quote from: atariman;262241
Brian
94 and up T-birds/Cougars all have a 4R70W which has no TV cable. A computer controls the shifts ;)
Tranny problem??
Quote from: 86XR7project;262384
well ive had a few of the mn-12's with the 4.6 (and I thought it was an AODE??? ) and ive never had a problem engine or tranny wise. Just change the oil/tranny fluid when necessary and it will last. My previous cougar was an mn-12 had 99,000 miles when i got it, and i put it up to 247,000 without any problems, still running strong when I sold it. :D
FOXLESS!!
Tranny problem??
Quote from: thunderjet302;262399
I knew that.....:hick:
