Topic: T3 coolant line and fitting - '86 TC (Read 660 times) previous topic - next topic
For an '86 TC (I'm guessing '83-'86 are the same).
I need the uppermost coolant tube and also the metal tube that connects to it that runs to the turbo...........
In addition, I need this fitting so I can hook everything up...........:burnout:
GOOD LUCK.  I went through this twice.  Your best bet for the fitting is a store that sells hydraulic supplies.  I just ran a rubber line to the upper tube.  I just took my whole turbo to the store.
As far as the upper metal tube, I would think you'll need to find one in a JY or someone who has one here.  I've never seen any repops.
