Topic: wireing disaster (Read 15164 times) previous topic - next topic
wireing disaster
Reply #60
You pretty much take out anything that had to do with the EFI system (upper/lower intake, injectors, .......) and swap a carbed upper/lower and more
FOXLESS!!
1994 Lincoln Mark VIII
wireing disaster
Reply #61
If your on a tight budget then that aint the way to go anyway, just keep searchin you will find one. Hell, I may be able to get you the wiring off a 3.8 at the yards here since that seems to be all they have....I will check this weekend if you want. Anyone know if anything later than an '88 232 wiring will work?
FOXLESS!!
wireing disaster
Reply #62
so how will that fix my wire problem??
wireing disaster
Reply #63
thnx because that carb swap thing was confusing me lol
wireing disaster
Reply #64
Quote from: 20thanniver-ls;262491
It eliminates most, if not all your wiring, I've never done it some im not totally sure. It can get expensive though.
FOXLESS!!
wireing disaster
Reply #65
I would put up a post in the wanted section. With all the people here that swapped out from a 3.8, I'm sure someone has a harness laying around.
wireing disaster
Reply #66
your right, it probably wont fix the wirng problem. ITs just another adventure down a fruitless path but if you have the time,, a carb does do about 20hp bolt on to most any v8.
The chassis harness is boogered up as well from what you were saying, ie- smoke at seat switches ect.
wireing disaster
Reply #67
Quote from: Haystack;262509
I got a main one from a 87 3.8 cfi motor. needs a couple wires reconnected to a connector, and I believe the ring connector for the solenoid.
I also might have the harness for the lights.
But isn't an 88 3.8 harness wired opposite, because the battery is on the drivers side like the V8s?
wireing disaster
Reply #68
maybe im not too sure about what im looking for but the one i need has about six harnesses that goes under the hood, along wit hthe solinoid rind connector and it goes through the firewall and it has a bunch of harnesses and wires that connect to the ignition and everything else on the inside and the fuse box
wireing disaster
Reply #69
Quote from: daminc;262737
or is there a way i can hook all the inside wires and fuse box and all to that wire harness
wireing disaster
Reply #70
I don't believe he is talking about the EEC wiring harness.
wireing disaster
Reply #71
explain?? what i eec wiring harness and what is what im looking for called?
wireing disaster
Reply #72
Quote from: 17needhelp;262838
The EEC (Electronic Engine Control) computer wiring harness.
The EEC is behind the passenger side kick panel. The harness goes to the fuel injectors and a lot of sensors and solinoids in the engine compartment.
The fuse panel and the ignition switch would be the power distribution harness.
wireing disaster
Reply #73
the harness im looking for has about six connectors that go to several parts under the hood then it goes through the firewall with a rubber thing around it (i guess to keep air out of the car) and has connectors that connect into the steering column and the speedometer and goes all through the dash, radio, cig lighter and clock. it has alot of wires the connect everywhere and the fuse box is connected to it and the lil switch that controls the headlights and all.. what is that called?
wireing disaster
Reply #74
I don't think the cable harnesses all have specific names. Describing where they go, like you did,is about all you can do.
The rubber firewall grommet is to keep poisonous engine bay gasses from getting into the cabin.
How bad is the old harness? Are any of the connectors damaged?
How many wires are burned up?
Maybe you can fix what you have.
Are any of the wires that went to the headlight switch burned up?
