Topic: any Bondo gurus here? (Read 2647 times) previous topic - next topic
i cant get a few dings leveled right.
 i mix the bondo and hardener to where its almost a pinkish grey color, then spread it kinda thick over the area. i let it dry for about 30min, then block sand with 120 grit paper. it always leaves a very, very shallow "dip" when i rub my hand over the spot.
1979 Ford Fairmont
[/B]
Don't sand with hand and paper,use a block.I let it dry for an hour (probably not necessary),but I like it thoroughly dry,then block sand,then glazing compound (when I'm happy with the bondo results).Sand it a little,check it.You can also spray a light coat of flat black on the area to look for high and low spots.Use a block,though.By the way,I don't know if anyone knew this or not,but,the Bondo brand spreaders are the color the bondo should be when mixed correctly.
how big are the dings?
Got a pic?
Vinnie, I never knew that. Thanks for the tip.
the dings are about the size of a quarter. i dont have any pics, and its dark outside right now.
ill try one more time, then say screw it. im not looking for anything show quality. i just want a good 20-footer job. :D
1979 Ford Fairmont
[/B]
Even with a 20 footer,use a block.You can get them different sizes.When you're "hand sanding",the panel can feel very smooth,but your hand and fingers are rounded,so,that is what translates into the panel after sanding.By using a block sanding method,it keeps everything flat.Patience helps while sanding.Don't wet sand Bondo (said as a "just in case").
Make sure you grind the paint out of the dings first. Use polyester filler. it won't shrink. bondo and spot putty will keep shrinking for a couple of months after your done, and usually show the infamous mini "ass print" in the paint..
If you use a block and they come back, use a longer one then. and also use the guide coat like Vinnie said.
I used a polyester filler as well.I have used Bondo with good results in small areas.I wouldn't use it in a deep dent,crease,whatever.I do like glazing compound on the finished sanded Bondo to fill in any pin holes that can,and probably will, be left behind.
once you get into multiple dings and warped imperfections on a panel. You need this and a long board after you fill. I'm sure you won't need this though.. ;)
Mmmmm,good stuff......especially with a sliced banana,a little sugar,and some milk.Tasty.
what is this green stuff called that i see a lot of people use?
1979 Ford Fairmont
[/B]
Quote from: 32VFoxBird;259436
duraglas, its bondo mixed with fiberglass.
88 Sport, custom white 140 mph gauge, 11 in brake upgrade, stock mustang headers, bassani x-pipe, cherry bomb vortec lers, HO conversion
it's the waterproof stuff
i went back over all the spots by block sanding with a wooden block(instead of the rubber 3M one) and it very smooth. i sprayed some black paint over the area, and you cant even tell where i bondo'd at. :)
1979 Ford Fairmont
[/B]
Quote from: 32VFoxBird;259549
Black paint.... Hmmmm.....
That blue would look awesome with black
