Topic: Idling problem when cold ( '91 5.0) (Read 1990 times) previous topic - next topic
Quote from: Sick88Tbird;259470
Looks like 14lb fuel injectors too... ???  Sure it's from a '91?  everything in that picture is '86-'88 correct.
'cept the aluminum valve covers ;)
Looking at some pics I have of MY engine, that one you posted APPEARS to have the old school 302/SO firing order as well.....
Differences between SO and HO:  http://www.coolcats.net/tech/advanced/ho_conversion.html
If that engine came out of a '91 cat; than that aint the original engine from that car....Unless the block was in the car and someone pieced it together without knowing too much about the differences...
The fuel pump is an electric I picked up at a napa store
What type of vehicle is the pump specified for?
[QUOTEthat one you posted APPEARS to have the old school 302/SO firing order ][/QUOTE]
Looks exactly like my '87. Didnt the HO motors from the mn-12's have an elbow on the upper? If i remember correctly my 93 Cougar HO had it.
FOXLESS!!
1994 Lincoln Mark VIII
Yes, as well as the 94-95 Mustang H.O.'s.
What did you use for a computer in it? I should say what comp?
