Topic: Dead Pilot's T5 swap. (Questions?) (Read 2423 times) previous topic - next topic
The AOD from a crown vic will be longer then your aod because it has a longer tail shaft.
Look around for a 94 up t5 from a v6. They are beefed up the same as a 93 cobra spec, but there longer. I'll bet if you had to get your driveshaft machined for that transmission it'll be the right length for that transmission. Its about 3/4 of an inch longer then the fox chassis specific one.
Just post a wanted on Corral.net  I had to drive an hour to go pick it up but he sold me every nut bolt and washer for the T5 swap out of his stang for 550.
-dZ
I dont know what it would cost to ship to you but I have a complete swap kit with everything you need for $800
87 TC
Quote from: Haystack;273638
NOPE I believe only P/U and LSC AODs are longer...
