Topic: HP,,, guess (Read 4728 times) previous topic - next topic
HP,,, guess
You know first off you look like a stalker, who just has to follow every post i ever made.
No. just a good memory.  That particular one stuck.  Took me about ten seconds to find it.
You look like a real A-Hole to everyone on here who knows me and that i have helped in the past.
Your half assed answer here helps NOBODY.
My usual response to you would be F OFF
I think we're all quite aware of that.
Secondly my car against your any day(since you brought it up)then we'll see you can build better.
Here's that argument I was talking about -- the "I have a blower so I'm better" routine you throw out all the time.  You know...the one I posted above.  If you truly have 500 HP, you'd BETTER win, you'd look silly if you lost ;) I wonder if you'd be as confident in a race that did not involve a straight run.
You wanna start a WAR because you have nothing better to do in your pitifull life fine,count me out.
I can think of someone YOU jump all over every chance you get.  Are you counting yourself out because you know I'm right?  BTW -- I thought you weren't insulting anyone......
However i will point out to the mods that he did insult me un purpose and should be warned.
I only told him to take a pill because he comes in here guns blazin.
I insulted you by giving the detailed answer this thread deserved?
Whatever....You're one of the most arrogant people I've had the displeasure of coming across.  Did I balk at your answer?  Yes, absolutely.  There's a difference.  Grow some thicker skin.
If you wish, feel free to PM me and we can banter some more.  This thread is getting muddled.
HP,,, guess
Can't we all just be friends?????????????
HP,,, guess
Quote from: flipnbird;257833
Who knows......
I digress.
Seems none of us have touched upon your other part of the original post:  The torque converter.  With respect to that have you thought about what to do for holding WOT past 5K RPM?
HP,,, guess
Can't be friends with a guy that thinks he knows it all(V8 demon) because he posts a small piece(copied from someone else) on ptv clearance.
No need to PM you,can't be bothered to argue with you anymore,here or anywhere else.
Simply put stay out of my face and i will do the same with yours.
However if you want to continue to be a STALKER and have an obsession with me(never came after you after that thread) then by all means continue this,i won't.
In response to flipn,i tried to help man but this is what i get from some people,sorry to screw up your thread.
HP,,, guess
I'll post where I please.
Deal with it.
HP,,, guess
The torque converter.  With respect to that have you thought about what to do for holding WOT past 5K RPM?[/QUOTE]
explain...........what should i do? is there something that needs to be put in/out of tranny to accomplish this?
HP,,, guess
Yes.  The stock Cougar/Thunderbird tailshaft governor will allow up to just under 5000 RPM.  The one that came in the Mustangs gave a bit more, maybe 400 RPM.
The Trans-Go shift kits come with one that's a step above that as well....It's the one I run.
Mucho in depth info here:
http://www.clickclickracing.com
HP,,, guess
Why Thank You Sir !!!!!!!!!!!!!!!!!!!!!!  I will look into this also..............I have a B&M (yea i know) shift kit in now and i always wondered why i can't hardly get above 5000 rpm.
HP,,, guess
Most shift kits don't address the tailshaft ;)
HP,,, guess
Reply #39
Man, this argument brings back memories. It's nice seeing that I'm not the only one that see's some people for who they are.
V8Demon, my car is faster than yours, my dick is bigger and you're dumber. TAKE THAT!
HP,,, guess
Reply #40
Quote from: Tbird232ci;257849
:rollin:
HP,,, guess
Reply #41
Yikes, I feel a bit over my head. Virtual fist fights and tech that I don't know enough to understand......
HP,,, guess
Reply #42
Quote from: 86XR7project;257856
That's ok, just stick to your fox bodies.
:mullet:
HP,,, guess
Reply #43
Sorry not quite understanding that comment. Where were you going with that one.
HP,,, guess
Reply #44
Quote from: 86XR7project;257859
Quote from: 86XR7project;257491
I'll stick with the fox body thank you very much.
