Topic: Sway bar links done...ABS light on.... (Read 6509 times) previous topic - next topic
Reply #45
.....or this?
FOXLESS!!
1994 Lincoln Mark VIII
Reply #46
Ive tried using the seperator tool (the second picture) and it didnt work. I put the forks behind the shaft and pulled and pryed but no go. Maybe im doing it wrong???
FOXLESS!!
Reply #47
Tried again and bent the forks on the seperator tool....
FOXLESS!!
Reply #48
Has ANYBODY ever done this on an mn-12?
FOXLESS!!
Reply #49
I've done it. Told you it wouldn't just fall apart :hick:
With the second tool ("pickle fork") you don't pry, you beat. Put the fork on the joint, beat the end of the handle to drive the fork in deeper. The wedge shape of the tool should separate the joint. This is assuming you've got a small pickle fork that actually will wedge itself in.
The first tool works too, but you might not be able to get it in place.
When in doubt there's always heat. If you have access to a torch you can heat the joint (heat the part the link goes into, not the link itself). When the part gets hot it should release its grip on the link. Just don't heat the sway bar end too much.
Reply #50
Quote from: Thunder Chicken;258126
video of pickle fork use on tie rod end....pics may help
http://www.ehow.com/video_2327949_remove-tie-rods.html
Reply #51
Yea lol experience knows best.... got any tips for the bottom part? just got the top off havin a little trouble (well a lot lol) with the bottom
FOXLESS!!
Reply #52
Same thing: Wedge the pickle fork in between the sway bar and the link, then beat the holy bejeesus out of it.
Experience may know best, but this is 15 year old experience. I did it on my '91 back in '94.
Reply #53
Well i succesfully removed and replaced my sway bar links....:D  Took it for a drive, purposely found potholes.......problem solved. No more annoying clanging. However, a new problem arises......my anti-lock light is now on. Coincidence maybe?
FOXLESS!!
Reply #54
I was just thinking, maybe i hit one (or both ) of my wheel sensors and knocked them out of place - sound about right?
FOXLESS!!
Reply #55
About the only way to tell would be put a scanner on it and check for codes. Without a scanner you can do a visual (look for broken wires) but unless it's something obvious it's just a  shoot
Reply #56
Yea i beat the hell out of the links while taking themn off im almost positive that i hit other stuff too.....but you are right the only sure way is to scan it...
FOXLESS!!
