Topic: Carb swap concerns! (Read 1608 times) previous topic - next topic
Carb swap concerns!
Does anyone know what gauges I'll loose the function of by doing a carb swap? I have a 88' sport thunderbird with buttstuffog gauges and I'm not shure what else I'll have to re-wire with the swap. Any help would be great!
Thanks,
Jonathan
~1988 thunderbird~
In hibernation, waiting for spring.
Carb swap concerns!
When I ran a carb on my 86, I had no issues with the buttstuffog guages.  The temp sender transfers to the carb intake.  The rest remain intact.
Carb swap concerns!
I was thinking that since my oil pressure and temp gauge wiring run through the EFI harness on the motor and run right to the computer via the harness I would have to figure out how to re-wire them...
~1988 thunderbird~
Carb swap concerns!
The wires can be left alone or spliced in if you are pulling the whole harness.  I left most everything intact when I did my swap so I could convert it back later (which I ended up doing).  The wires do not run through the computer.
Carb swap concerns!
Quote from: 86T-bird;256432
They don't run through the computer? Thats great! I just have to locate the wiring and pull it out of the harness. All of my EFI stuff is going bye-bye so I'll have to do a little splicing.
~1988 thunderbird~
