Topic: EL Coach Lamps (Read 3524 times) previous topic - next topic
EL Coach Lamps
I would love to get the ones on my cat working. I'll have to check and see if the inverters are good and try and rebuild them. Always liked how they looked.
85 Tbird 5.0
78 F150 351w
13 F150 4x4 3.5 Ecoboost
EL Coach Lamps
Always wished mine worked. If I could do it cheap enough I would fix them.
EL Coach Lamps
Quote from: Cougars 2 go;255994
Well, if anyone finds new parallel electrode EL sheets that are white with and without power, let me know so I can finish mercury-man's lights
C2g,
I just rechecked my source (cooltronix) and no change to the white glow foil sheets.  Still pink in the off state.  However, the opaque OEM diffuser lens should help mask the pink foil.  I could be wrong though.
dg
EL Coach Lamps
So.. Does anyone have any info on replacement inverters? I just picked up a pair of Heritage Coach lamps today and they do not seem to be working...
EL Coach Lamps
Any updates on this?
Found the inverters to be bad on my good set also. :mad:
In fact~I've found the inverters to be bad on about 4 sets. :toilet:
