Topic: The Sport's small video.... (Read 8066 times) previous topic - next topic
Sweet!!!!!!!!!!!!!!
[/IMG]
Just enjoyin the ride!!!!
Nice, sounds great. :cool:
Matt
Sounds killer, man. But that video needs to be at least another minute longer. :P
sounds good man, but where is the smoke?  ;)  need to hit that middle pedal after dumping the clutch for some fun....
making me itch to go out and burn some rubber on the cat....
Quote from: yellow86coogr;255395
Niiiiiiiicce. O yea. Need a little longer video. Put on some trash tires and smoke em up, :D
THAT'S an idea.I didn't mind doing the burnout,but,I also try to take it "somewhat" easy.These tires aren't very old at all.I do have 10 more wheels and tires though.I may just bolt a set on and blaze them.
Blaze!
Blaze!
Blaze!
Blaze!
Blaze!
10 more wheels and tires?  At least two of those tires could be sacrificed for the forum's enjoyment. lol
burn a old set till one or both pop!!!:burnout: :burnout: do the old disaper into smoke trick :shakeass:
ok, first make no mistake, LOVE your car Vin, although greens not my color and I don't usually like it, yours looks good.
(now to play devils advocate)
About this video, I'm a bit let down, I don't think you need to worry much about burning up your rubber.. I watched that rear tire over and over.... it ain't spinnin!
Wat you lacking there ... posi or you burning more clutch than tire?
Here... let me demonstrate.... it's suppose look like...
:burnout:  <----THAT
time for a 4-clutch pack mod
1979 Ford Fairmont
[/B]
it sounds like the clutch is slipping or is it just the vid
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
you shift like a lesbian...
The tires were spinning.These tires don't leave a lot of rubber,nor leave a lot of smoke.It's like Kitz said early on,Rikenes are like that.I was actually let down on the firt burnout I did with them.
Shifting like a lesbian?Show me your video Sprayin88cat so I can see how the pros do it.
When time allows,we'll give it another shot.
