Topic: FOR SALE 1987 20th Anniversary Edition (Read 3824 times) previous topic - next topic
Needs some TLC but runs and looks good. $1,000  or OBO. In NE PA.
Bloomsburg/Berwick area. Has slight right front fender & header damage, I have the parts to fix it.Here are some pics but hard to see damage!
Re: FOR SALE 1987 20th Anniversary Edition
Quote from: mrsoftee123
Needs some TLC but runs and looks good. $1,000  or OBO. In PA.
Where in PA?  Any accident history?
You might want to move this out of the misc. section.
1987 Thunderbird 3.8. Sold :(
NE PA Bloomsburg / Berwick area. Slight Front fender & header panel damage
Do you have any pictures of the damaged areas?
pics added
Thanks for the pics.  Is that a factory moon roof?  Have the transmission or engine ever had any work done to them other than the preventive maintenance?
Does it have:
-power antenna
-illuminated entry
-keyless entry (doesn't seem to be in pics but to be sure)
-automatic climate control
-engine block heater
-Traction-Lok axle with 3.08 gears
Just to let you know, I might be interested but for less than $1,000.00.
If it doesn't have those options you'd be able to add in the T-L axle, block heater and power antenna relatively easily.  But the ATC, illuminated entry and keyless aren't as easy to add on.  (ATC would probably be the worst of the three) Just something to consider.
Yes the moon roof is factory, engine & tranny are stock. Has power antenna the other items you mentioned it dose not have.
Quote from: Ifixyawata
Yeah, thanks, you read the question in my mind.
Sold
