Topic: Tube K Member/rear control arms (Read 2251 times) previous topic - next topic
so heres my question I have an 86 Thunderbird and im wondering if a tube k member for a fox or sn95 mustang as well as the rear control arms fit on my thunderbird with out major modifications of parts or the car.
86 Tbird 3.8 auto soon to be 5.0 AOD I hope
89 mustang GT convertible donor car
94 explorer xlt
adjustable upper and lower rear control arms will fit. The Fox cat/birds arms are longer, but adjusting them out will fit. The 79-93 tubular K member will bolt on with little modification. I was told that washers as spacers were needed to make it all line up correctly.
Quote from: Lightningbird;251745
Not entirely true.  TBird/Cougar uppers are over an 1" longer and that is out of the realm of adjustment of most adjustable Mustang ones.  The lowers are close enough (3/8"-1/2") that adjustable Mustang ones will work.  There are vendors that make Tbird/Cougar-specific rear control arms.
There are SEVERAL threads that already discuss this.
I JUST had this talk with Daminc.He has convinced me that I need the rear control arms (tubular).Less than $200.00 shipped.Not bad at all.
UPR sells a set for a mustang with a 9" rear that adjust to the perfect length 1" longer then the mustang ones. These are the ones I got.
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Quote from: vinnietbird;251780
Vinnie-is that all four of them? If so where's the link?
Ken
It is all 4 of them with the CoolCat discount...shipped.Thanks Daminc for hooking me up.
http://www.cheperformance.com/CartGenie/prod-77.htm
Everybody buy them.
Quote from: vinnietbird;251810
Everybody buy them.
Thats not for all ajustable, I paid more a while back.
http://www.cheperformance.com/CartGenie/prod-103.htm
Before discount, and thats just the lowers. you may want to go with the lower ajustable now in case you want to change ride hight now. because we all change are minds as we build.LOL,  As noted here if you use the ajustable with stock springs it will raise the rear!
I won't be lowering the rear of the Sport much at all....if any.I'm going to buy the set that Daminc bought and sell my bushings that I bought and let it be.I don't want it too low,in this part of the country,I need a little ground clearance.The front is my main problem.I can almost walk under the car.
Then you need bigger tires to make it look right, " TRUST ME " he he, you can do a minny tub to fit them.
I bought the black ones to match all the black underneath. I'm not into the flashy sort of thing. LOL
thanks for the help. I havent done much research on the site yet or in general acctually ive had the bird sitting in my yard for a while and finally decided to do something with it when a tree fell on my 89 Gt
94 explorer xlt
