Topic: Glossary (Read 7532 times) previous topic - next topic
Glossary
I'd actually spent a bit of time on a glossary for these cars and was going to put it on my website, but never got around to it. Here's the work I'd done so far. If people want it, I'll make it into its own thread and sticky it into the tech section:
  Note: All references to “these cars” and references to model years that a component was used refer to 1983-1988 Thunderbirds and Cougars for the purpose of this list. For example, although this glossary mentions that these cars never came with HO engines, I am aware that 1991-1993 MN12 T-Birds and Cougars could be had with 5.0 HO engines. “These cars” means 1983-1988 T-Bird and Cougars ONLY.
  • 20th Anniversary Cat, or 20th,      or “Anny”: A special edition 1987 Cougar built to commemorate the 20th      anniversary of the model. Based on the LS model, but with unique paint,      interior and equipment. Approximately 5000 were built.
  • 2.3t or 2.3 turbo: A turbocharged      2.3 liter SOHC 4-cylinder engine. Available only in Turbo coupe and 84-86      XR7. Featured an intercooler on 87-88 models.
  • 35th Anniversary      Thunderbird: A special edition 1985 Thunderbird built to commemorate      the 35th anniversary of the T-Bird. Approximately 5000 were      built. Featured unique paint and interior, as well as some unique features
  • 3.8 V6: The base engine in 83-88      Thunderbirds and Cougars. A 90-degree OHV cast iron design with aluminum      heads. 1983 US      models and 1983-1986 Canadian models featured a 2-bbl carburetor.      1984-1987 US models and 1987 Canadian models featured a CFI fuel injection      system. 1988 featured port fuel injection.
  • 4-eye: A car with four headlights.      When talking about these cars it means 83-86 models.
  • 5.0 V8: An optional engine in      1983-1988 Thunderbirds and Cougars. Featured CFI fuel injection until      1986, when it was replaced with port fuel injection (EFI). The 5.0 V8      installed in these cars was the non-HO, or “SO” version of the engine, not      to be confused with the HO version installed in Mustangs.
  • 7.5” rear axle: The rear end      housing installed in all 83-86 T-Birds and Cougars, as well as most V6 and      V8 optioned 87-88 models (except 1988 XR7 and some 1988 Sports). Usually      featured open differential, but some models (TC, Sport and XR7) featured      traction lock. T/L was optional in other models. The 7.5” refers to the      diameter of the ring gear.
  • 8.8” rear axle: A larger, stronger      rear axle. Standard equipment in 1987-88 Turbo Coupe and 1988 XR7. There      have been cases of this rear axle being featured in 1988 Sports as well.      Featured traction lock in all Thunderbird/Cougar installations. Was      equipped with disc brakes on TC, drum brakes on all others.
  • A4LD: a light duty automatic      transmission available in 1987-1988 Turbo Coupe. 4-speed design, fourth      gear is overdrive.
  • ABS: Antilock Brakes. Was standard      equipment on 87-88 Turbo Coupe
  • ACT: Air Charge Temperature      sensor. This is a sensor in the intake manifold that measures the      temperature of the air in the intake.
  • AOD: a medium duty 4-speed      automatic overdrive transmission. Was standard equipment on 83-88 5.0      models, optional on early V6 models, standard on later ones.
  • Batch Fire or Bank Fire: A type of      multi port fuel injection. Unlike SEFI, which fires each individual      injector in sequence, batch fire fires a bunch (or batch) at once, usually      in banks. This is a simpler EFI setup, with only two injector circuits      from the engine computer, instead of a circuit for each injector – in      fact, it is electrically similar to CFI. 1988 3.8 V6 cars are batch fire,      as are many Ford trucks.
  • Box Fox: A 1980-1982 T-Bird or      Cougar. Based on the Fox platform, just like the 83-88, but much more      boxy. Box Fox Cougars were even available as four-doors and station      wagons.
  • BCS: Boost control solenoid. Used      in turbo models, it’s basically a boost “dump” controller which opens up      when boost gets too high. It opens the wastegate on the turbo. Often      replaced by an aftermarket, adjustable boost control valve such as a      “Gillis valve”
  • C3: a light duty 3-speed automatic      transmission available in 1983-86 Turbo Coupe and 1984-86 XR7
  • C4: A medium duty Ford automatic      transmission, was never factory installed in 83-88 cars. Was a three-speed
  • C5: An improved version of the C4      transmission, was standard equipment on 83-86 V6 models. Was  a three speed.
  • CAI: Cold Air Intake: An      aftermarket intake duct. True CAI takes the air from outside the engine      compartment (hence “cold air”), but some cheap kits have a conical filter      mounted inside the engine compartment
  • CFI: Central Fuel Injection.      Featured two fuel injectors mounted on a central throttle body. Similar in      appearance to a carburetor, but fuel is metered electronically.
  • E6 or E6SE: The heads found on      1986-1988 SO 5.0 engines. Generally considered undesirable due to poor      flow
  • E7 or E7TE: The cylinder heads      found on 1987-1995 HO V8 engines. Feature better breathing than the heads      found on these cars, which lets the HO make more power.
  • EATC: Electronic Automatic      Temperature Control. The title pretty much sums it up: An automatic      climate control system. Optional in all models, all model years.
  • ECTS: Engine Coolant Temperature      Sensor. The engine computer uses this sensor to determine the engine      temperature, and uses the information to determine fuel mixture (a cooler      engine requires more fuel). Not to be confused with the temperature      sender, which only sends information to the temperature gauge in the dash.
  • EEC, or EEC-IV, or EEC-V:      Electronic Engine Control. The IV or V denotes the generation. All      1984-1988 T-Birds and Cougars (except Canadian V6 models) use EEC-IV. 1983      used EEC-III. 1983-1986 Canadian V6 models used carburetors and did not      have electronic engine control. EEC-V is a newer, OBD-II compliant system.
  • EFI: Electronic Fuel Injection.      Technically, CFI is a form of electronic fuel injection, but Ford reserves      the term EFI for later multi-port designs.
  • Elan: A trim level on Thunderbird.      The most luxurious trim level but considered to slot below Turbo Coupe.      Discontinued in 1986, replaced with LX.
  • Fila: A trim level on Thunderbird.      Considered to be a special edition, it was a cross-marketing thing between      Ford and Fila. Discontinued in 1986
  • Fox: The basic platform these cars      are built on. Some other cars that share the Fox platform are 79-93      Mustang, Fairmont, Zephyr, Capri,      Continental, and Mark VII
  • GS: A trim level on the Cougar,      typically the “base” model
  • Heritage: A trim level on      Thunderbird. Discontinued in 1984.
  • HO or High Output: The 5.0 engine      found in 1987-93 Mustang GT and 1988-92 Lincoln Mark VII, but not factory installed in      T-Birds and Cougars. Makes approximately 50% more horsepower than the SO      version of the 5.0 V8 (225 for HO VS ~150 for SO) and is a common upgrade      for these cars. Features forged pistons, better flowing heads and intake,      more aggressive camshaft, larger throttle body, and 19 pound fuel      injectors. The SO 5.0 can be upgraded to HO specs using HO spec top end      parts and camshaft, but because of its flat-top cast pistons it is limited      in further modifications.
  • IAC: Idle Air Control valve. A      small motor or solenoid on the throttle body that allows air into the      engine while idling
  • IHI: The turbocharger installed on      1987-1988 Turbo Coupe engines
  • IRCM: Integrated Relay Control      Module. A subsystem of the 1987-88 Turbo Coupe’s electrical system.      Contains several relays controlling several different circuits.
  • LCA: Lower Control Arm, when      talking about these cars, usually in reference to the rear suspension
  • LS: A trim level on the Cougar,      typically the “midlevel” model
  • LX: A trim level on Thunderbirds.      The most luxurious trim level, but considered “below” Turbo Coupe.      Replaced “Elan”
  • MAP or BAP: Manifold Absolute      Pressure sensor. On Speed Density cars the MAP helps the engine computer      determine how hard the engine is working (and subsequently, how much fuel      it needs). When converting to a MAF system the vacuum line is removed from      the MAP sensor, turning it into a BAP sensor (Barometric Absolute      Pressure), which is only active before the engine is started and acts as a      type of altitude sensor.
  • Mass Airflow Sensor, or MAF: a      system of measuring engine air intake so that fuel can be metered      accordingly. Because it measures the air the engine is using it adapts      easily to modifications. Was never installed in 83-88 T-Birds and Cougars      but is a popular upgrade. Non-turbo T-Birds and Cougars used a Speed      Density system, while turbocharged models used a VAM system
  • MN12: The 1989-1997      Thunderbird/Cougar platform. Completely different than the Fox, with very      little if any parts interchange ability.
  • Multi-port fuel injection, or MPFI, or      Port Fuel Injection, or EFI: A type of fuel injection that uses a fuel      injector for each cylinder. 1988 3.8, 1986-88 5.0 and 1983-1988 2.3t      engines all featured this type of injection.
  • NATO: No, not that NATO. On this      forum NATO means another forum dedicated to Turbo Coupes.
  • New Edge: The name for 1999 and      newer FWD Mercury Cougars
  • O2 or Oxygen sensor: A sensor      mounted in the exhaust stream that measures the oxygen content of the      exhaust gasses. The engine computer uses this reading to fine-tune fuel      mixture. This is a reactionary setup – the sensor sends info to the      computer, which looks at the reading and decides whether to add or      subtract fuel, which it then does and then monitors the O2 sensor to see      what effect the change had. This check/change/recheck procedure is called      “Closed Loop Operation”. The O2 sensor must be hot to function, so the      computer will not go into closed loop mode on a cold engine. On V-type      engines (V6, V8) there are two sensors, one for each bank. EFI versions of      these cars use a four-wire “heated” O2 sensor to help get into closed loop      mode faster.
  • Posi or Positraction: A generic General      Motors term for limited slip rear end, often mistakenly used to describe      Ford rears. The proper term for it is “Traction Lock”.
  • PRC: Programmed Ride Control. An      electronic suspension system exclusive to 87-88 Turbo Coupe.
  • Quad Shocks: A second, horizontal      set of shocks on the rear axle designed to reduce axle hop during hard      launches. Standard equipment on Turbo Coupe, Sport, and XR7. May be found      on other models as well.
  • SEFI: Sequential Electronic Fuel      Injection. A type of multi port fuel injection in which each fuel injector      is activated just before the intake valve opens. The injectors open in      sequence according to the firing order, hence “SEFI”. 1986 and newer 5.0      engines and all 2.3t engines used SEFI.
  • SFC or Subframe Connector: A brace      between the rear and front subframes, which greatly strengthens these cars      by tying the two ends of the car together. Usually welded in, though some      are bolted in.
  • SN95: The 1994 to 2004 Mustang.      This chassis is a popular donor for suspension components into Fox cars      such as ours. 2005 and newer Mustangs are built on the S197 chassis.
  • SO or Standard Output: The      low-performance 5.0 V8 installed in 83-88 T-Birds and Cougars. Horsepower      ratings ranged from 130-155.
  • Speed Density: The fuel metering      system used on non-turbo T-Birds and Cougars. Unlike a MAF setup, this      system does not actually measure the air entering the engine. It uses      readings from the TPS, MAP, ECTS, and other sensors, then uses a      mathematical table to determine how much fuel the engine needs. This is      considered to be a good setup on a stock engine, but because it does not      measure incoming air it cannot compensate for engine modifications that      increase airflow (and almost all engine modifications increase airflow). Because      it does not work well with modifications it’s often swapped for a mass      airflow system using Mustang components.
  • Sport: A trim level on the 87-88      Thunderbird. Slotted between the LX and Turbo Coupe, it featured a 5.0 SO      engine, stiffer springs, traction lok rear end, quad shocks, and a floor      shifted automatic transmission. 1987 Sports featured a full digital dash      and base style seats, 1988 Sports featured a full buttstuffogue dash and Turbo      Coupe style seats.
  • Star Wars Dash: The optional,      fully digital instrument cluster available in 1985-1988 models. Features digital      tachometer, built in fuel computer and multi-gauge (oil, volt, water temp)
  • T3: The turbocharger installed on      1983-1986 TC and XR7 models
  • T4: A larger turbo. A common      aftermarket upgrade
  • T3/T4 Hybrid: Just like it sounds,      a turbocharger that shares features with T3 and T4 turbochargers
  • T5: The Borg-Warner 5-speed manual      transmission available in 1983-88 Turbo Coupe and 1984-1986 XR7
  • TFI: Thin Film Ignition. This is      the electronic ignition system used in Fords with EEC-IV. The TFI module      is mounted close to the engine and is pr0ne to heat related failure
  • TPS: Throttle Position Sensor
  • Traction Lok, or Traction Lock, or      Trac Loc: A limited slip rear differential. Was standard equipment on      Sport, Turbo Coupe and XR7. Was optional on all others.
  • Turbo Coupe or TC: A trim level on      Thunderbird. Featured 2.3 turbocharged four cylinder engines. 1983-1986      were similar to other Thunderbirds with upgraded trim, suspension and      interior. 1987-1988 differed significantly from other models, featuring      unique hood, header panel, and wheels, plus several high tech features not      available on “lesser” Thunderbirds, such as PRC and ABS (see elsewhere in      glossary for definitions).
  • TV or Throttle Valve or Throttle Value      cable: A cable that connects from the transmission to the throttle      lever, it works with the governor in the automatic transmission to      determine shift points and feel. MUST be properly connected and      functioning, or it can cause transmission failure very quickly. The      plastic bushing on the cable where it attaches to the throttle lever is      pr0ne to failure.
  • VAM: Vane Air Meter – this is      similar to the MAF system in that it measures airflow into the engine, but      unlike a MAF system (which heats a thin wire, then measures how the air      cools it) this setup has a spring loaded flapper door attached to a      variable resistor. The more air enters the engine, the more the door is      pushed open. A MAF system only measures part of the airflow, VAM measures      all of it. Because it requires the air to push a door open it creates a      restriction in the air intake system. This is the metering system used on      2.3t models.
  • XR7 or XR-7: A trim level on the      Cougar. 1984-1986 featured the turbo 2.3 four-cylinder and was the Mercury      sibling to the Turbo Coupe. 1987-1988 featured the SO 5.0 and were      basically the Mercury equivalent to the Thunderbird Sport.
Glossary
Nice
Glossary
oh im so glad i found this, took me a while ,but im fullfilled now.great info
302 baby ,yeah
Glossary
H/C/I: referring to an engine that has Heads, Camshaft, and Intake manifold modifications.
There's also the World Class T5 trannies, usually abbreviated WCT5, which were featured in the '87-'88 TC's, as well as 5.0 Mustangs after a certain year, I forget the nitty gritty details of all that though.
Maybe someone could combine all the pertinent info and make a thread, sticky and all..?:bowdown:
Glossary
LS=Limited Slip for us old school folk. :D
1987 TC
Glossary
Great job and many thanks Thunder Chicken on the detailed list, now I don't need my secret decoder ring!  Seriously, because as a new owner of a Cougar and being somewhat new to the garage/tool area..I'll admit I don't know diddly and am sometimes embarassed to ask 'what does that mean?'
The following is my personal contribution as I've used it quite frequently.
AS: Aww SH*T.  A technical term often used by newer members quickly followed by the deep sigh and shaking of the head from side to side as they realize the complexity of the situation they're about to undertake.  In some cases, its used after realizing they've removed a vital part unnecessarily and need to reinstall it hoping no one noticed.
~In less enlightened times, the best way to impress women was to own a hot car. But women wised up and realized it was better to buy their own hot cars so they wouldn't have to ride around with jerks. ~
--Scott Adams.--
~Did you ever notice when you blow in a dog's face he gets mad at you? But when you take him in a car he sticks his head out the window. ~
--Steve Bluestone.--
Glossary
awesome list thunderchicken. You guys left out ECU/ECM - Electronic Control Unit/Module A.K.A. EEC which was up there
