Topic: Instrument cluster went Blank, but still lit up? (Read 2870 times) previous topic - next topic
morrison.344, After pulling everything in the dashboard area (like you have) we too could not find the short. So we started checking in our engine bay and that was where we found 3 loose wires (no insulation) on the drivers side touching the wheel house (frame). What was real disturbing is that everytime I got in & out of our cougar the fuse kept going out. My weight was just enough to move those wires and they made contact with that metal frame and the fuse kept going out. So in the end I'd say check out all wires leading in and around your "engine bay". LOL ;)
what have you done to the car lately? radio swap? amp ect?
Ok i took a volt meter and read the voltage on the battery with the car off the battery read 12.5 and with the car on the voltage read 15.1 with nothing on, it dropped to 14.9 with the headlights on.  I believe it should be 14.5.  Is 15.1 high enough that the voltage regulator could be bad in the alternator?
Quote from: morrison.344;248389
That's a little higher than typical but not enough to worry about.
If it goes higher than that  when you rev it up then the regulator is bad.
