Topic: few axle questions (Read 1347 times) previous topic - next topic
few axle questions
building the mustang strictly stock now *was a 4cyl car*, the axle swap for the cougar is done.
to swap a mustang 7.5 to 5 lug, what is needed? is it the same as the thundercats? I know the tbirds have a wider track. worse comes to worse i can switch complete rear axles from a 'bird. also is there a length difference in drive shafts from a 5spd to a aod on the stang?
few axle questions
all 79-04 mustangs share the same length driveshaft that have solid axles. the difference is the trans yoke.
you would use driver side ranger/broncoII axles or passenger side from an aerostar.
1979 Ford Fairmont
[/B]
few axle questions
ok cool, so it's the same setup,someone told me different and i got confused...should always follow my own judgment:beatyoass:
few axle questions
Quote from: 86Tbuzzard;248125
Not sure what you mean by "the same set-up".
To keep the narrower Fox Mustang track, you need to use the axles mentioned.  I'm pretty sure it's Ranger drums you need to use as well.
few axle questions
same as in, far as axles and ranger rotors for a 5 lug, i got 2 ranger complete axles coming,for axle shafts, and gears
