Topic: Nasty vacuum lines (Read 2878 times) previous topic - next topic
Nasty vacuum lines
So whats the cure for that?
FOXLESS!!
1994 Lincoln Mark VIII
Nasty vacuum lines
Quote from: 20thanniver-ls;247942
Make sure the theromostate is closed when the car is cold (ie the upper radiator hose should be easy to squeeze when the engine is started and the car is cold as no water is flowing through it. If it's firm when the car is cold the t-state is stuck open). Also don't idle the car when it's cold. I drive my 95 all year and even when it's below 0*F in the winter I just start it and drive off. I do start the 88 1-2 times a month in the winter but only when it's above freezing. Plus before I drive it in the spring I change the oil to get all the  out that forms from sitting for 5 months.
Nasty vacuum lines
Well im going to repalce the vacuum lines today, but im not really sure which ones i should replace, where all the main vacuum lines really are, anybody got a link to a diagram?
FOXLESS!!
Nasty vacuum lines
do a search
