Topic: Special symbols (Read 3162 times) previous topic - next topic
Special symbols
Alt-0nnn  90° ¼ ½ ¾ ® ± ÷
copy & paste from character map-  Ψ ΏΏ
Just wanted to se if this worked.
Special symbols
????  Where is this "character map?"
® ¶ Æ %
*Edit*  Nevermind, found it :D
Special symbols
KoЯn
So thats how everyone does that. Character map FTMFW!!
85 Tbird 5.0
78 F150 351w
13 F150 4x4 3.5 Ecoboost
Special symbols
Code: [Select]
[html][quote][/quote][/html]
remember it easier to fix them, than to find them after they been crushed.
V6 = juvenile delinquency!
Special symbols
huh? whatcha trying to do?
85 Tbird 5.0
78 F150 351w
Special symbols
OK, where's the character map?
Special symbols
Type in "character map" in the run box on the windows main toolbar.
THere are a couple in google as well.
Special symbols
Quote from: V8Demon;246974
Hmmmm
I got a Mac. I'll try google
Special symbols
Jerry, on the Mac OS it's usually at the bottom of the Edit menu of nearly all programs (Edit > Special Characters...) or Option-Command-T. It's actually part of a control panel (Apple Menu > System Preferences > International). Be aware that using this character palette puts a country flag on the top right side of the screen. You can deactivate it in the International control panel though, under the Input Menu tab.
Adobe programs have their own character menus that don't really sync with the Apple OS, nor Windows.
On a Windows PC it's usually under Start > All Programs > Accessories > System Tools > Character Map.
(Had to get in front of the PC to check LOL)
Special symbols
Thanks, Eric
got it
✏☤Ň❡★★★★✞₁¾¾@§¶
Special symbols
Some of the symbols can be selected by putting the numeric keypad in numeric lock. Then hold down alt and type the decimal code on the numeric keypad.
Example: alt 0188 = ¼  alt 0247 = ÷ alt 0176 = °
Accessories/System Tools/Character Map/Font Arial
Select a character. If it can be selected with keystrokes, the code will be in the lower right corner.
