Topic: Engine Lift Plates? (Read 3158 times) previous topic - next topic
Engine Lift Plates?
If its not pull , is it sideways? ,  I seen 5's bend and 8's snap.
Thats real world use.
Engine Lift Plates?
The figures I posted are just theoretically what they could withstand in tension. With a parent material the same strength of the fastener, you need ~1D of thread engagement to keep the fastener from pulling out from the parent material (stripping the threads). If the parent material is half as strong as the fastener, you need ~2D engagement. 1/3 strength, ~3D - etc...
If you don't properly torque the fasteners before lifting or use some kind of eye that leaves a portion of the fastener unsupported, you will reduce the load capacity.
Engine Lift Plates?
I never had any problems.. I used all thread ( Cheap all thread) and cheap nuts through a tiny chain and had no issues at all...
Engine Lift Plates?
Quote from: Haystack;246063
not yet! sorry my life worth more than cheap nuts through a tiny chain !
remember it easier to fix them, than to find them after they been crushed.
V6 = juvenile delinquency!
