Topic: In progress Sport pics.... (Read 49905 times) previous topic - next topic
Reply #270
 she is looking SSWWEEEETT !!!!, can't wait to see the full picture with everthing done.,,,,,,,,,,,,,,,,, by the way, how hard was it to put the fuel door on??
Reply #271
Quote from: flipnbird;249239
X2 :burnout:
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Reply #272
It took me about an hour and a half.I was trying to protect the paint on it and the car,so,I went slow.First,it was on my blue Thunderbird (in the banner),and I had forgotten how I installed it.Anyway.......From a personal standpoint,If you have a gray car,or very light colored car (white,gold),then the lid would look good natural aluminum.If you have a darker car,as my blue one was,I would color match the lid.To me,even on my old Bird,the gas lid was distracting and looked like a big silver dot on the side of the car,and didn't really have anything it matched.It was somewhat out of place.That is my own opinion,and the ultimate decision is of the the owner and what he/she likes on their own car.I think the painted lid has a more "finished" look.
These lids can be had on Ebay fairly cheap at times on Ebay.I got mine through Ford when the Bullitts were new.Here are the steps I took to install the Bullitt lid on the Sport................
1. I removed the gas cap (so I could fit my hands in that tiny area),screws that holds the inner filler area to the car and the two rubber bump stops that cushions the fuel door when it closes.
2.I test fit the Bullitt lid.It sat in too deep for me,I wanted it flush with the body,so,I have some thick gasket material,I traced the gas lid onto it,then cut it out about a 1/8 of an inch smaller because the back of the Bullitt lid is tapered.After making the gasket "ring" and tpuppies it to fit around the gas lid hinge,and cutting holes for the 6 fasteners,fit the lid and the gasket to the car.Everything was flush,I'm happy.
3.Using the gasket as a template,I fit it to the car,and checked that all 6 gas lid fasteners would have a place to bolt down.3 didn't.I used a Sharpie marker to draw dots where I needed to drill or remove metal (all very simple mods,and the stock lid can be re-installed if need be).
4.Looking at the gas lid area,at about the 8 and 10 o'clock positions,I drilled two holes through the body and the filler are plastic and metal framing for the gas lid fasteners.
5. At about the 3 o'clock position,I used my Dremmel and cutoff wheel to remove about a half square inch of metal that was in the way.
6. I taped the car off REALLY good and painted the recessed gas lid area of the body black.
7. I applied a very thin layer of black RTV to the lowest flat area of the body where the gas lid fits to hold the gasket in place.
8.I installed the gas lid with black cap screws (1 inch long allen head bolts,whatever) and small washers and locking nuts (5/16 head) after making SURE it was centered.It's easy to let it fall a little and bolt it on crooked.
Note: if you're keeping the gas lid natural aluminum,you will still have to bey new fasteners (I used stainless buttonhead screws on the blue car).The bolts that come with the gas lid new will not work.Half of them are decoration only.I removed them all (just unscrew them) and tossed them away for the new fasteners..
9. Took pics of the gas lid so people here wouldn't yell at me.
10. Done.
Reply #273
Now,I'm going out to take pics of the Mach 1 spoiler................
O.K.,I'm back,here are a couple of pics.......
Yes,I know the car sits high.I'll take care of that when I swap the strut bushings and install the larger front brakes.For now,it'll do.
Reply #274
hey can you take a pic of the gas lid from farther away, I want to see how much smaller it looks with the entire car in the picture. I might steal your custom idea:mullet:
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Reply #275
Let me step outside and take care of that for you.
Reply #276
Here it is.Now remember,the actual lid as a whole is almost the same size as the stock lid,BUT,the actual door itself is smaller.
Reply #277
Vinnie, Is your trunk lid up a little bit by the back window or are you standing at an angle by your Sport ????
Reply #278
It's up a tiny bit.I need to adjust it someday......maybe.LOL.
Reply #279
V-man, Does that trim piece for the quarter panels have a chrome strip on it like your bumpers do ?
Reply #280
Thanks Vinnie, for the writeup on the gas door. I've always wanted to put one on, someday, someday.:burnout:
Reply #281
Quote from: mercury-man;249261
Yes it does.Once the trim pieces get here,I'll install them.I should have the bumper cover trim painted by then (hopefully today0,and have the new chrome strip installed as well.
Reply #282
does it mount the same.
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Reply #283
No,the 6 bolts that go around the perimeter of the lid hold it onto the car,the gas lid has it's own hinge that is self contained.The outer ring of the lid and the center part are two separate pieces.Very solid as well.
Reply #284
More progress.I got the bumper trim painted,along with the trim between the side windows,installed brand new chrome trim on the bumpers,and installed the front fender trim.Hopefully,I'll be able to paint the window trim (front and rear) after work tomorrow.70 degrees today.Supposed to be warmer tomorrow.WOO-HOO !!!!! Now for the update pics........
Front angle......
Front.....
Last but not least,my helper and my best buddy in the world,Alex (aka "Bug")...
