Topic: Oil?????????????????? (Read 11173 times) previous topic - next topic
hummm,,, I thought rotella of all makes was good enough.
May switch to amsoil,, dono yet.
I have alot of info about amsoil on my site in my sig.
2 88 TC's (1 is the 2.3t race car, other v8 maybe?)
06 dodge dakota 4.7 v8
79 chevy k-10, built 350/turbo 350
Diverse ain't I?
AMSOIL Dealer
earlier tonight this topic came up at my lil gas station.  I couldnt for the life of me remember "zddp"
anyway, this thread can now be found in my diy link,,, where it wont get lost:D
Thanks for the mention in the description!!
Diverse ain't I?
AMSOIL Dealer
I run nothing but royal purple.
I run it in my cars, my motorcycle, my lawn mower(my PUSH mower and rider), ran it in my old ATV, I swear by and will use nothing but. That is unless I want to clean out the motor, and I use motorcraft synthetic blend for that.
Motorcraft, and K&N oil filters ONLY, nothing but.
AFAIK THIS is the most comprehensive and UP TO DATE oil filter comparison right now....
The conclusions:  http://www.knizefamily.net/minimopar/oilfilters/opinions.html
Motorcraft
The one I opened in 1999 seemed to be a Purolator hybrid.  It had the Premium Plus case (anti-drainback valve, gasket, etc), but with what appeared to be a Pure One filter element.  This was a cheap way to get a Purolator Pure One.  It is sold at many locations including Auto Zone, Pep Boys, etc.  I have heard from several people that Motorcraft seems to switch between Purolator and Champion Labs as the manufacturer so be observant.  The Motorcraft I took apart in 2008 appeared to be a regular Purolator Premium Plus.  Not worth the extra couple of bucks anymore in my opinion, but it probably looks snazzy under a Ford hood.
**Edit** Look at this thread on the RYCO filters from Australia (perhaps better than anything we could have gotten in 1999)
http://www.fordforums.com/f497/ryco-oil-filters-warning-124762/
I like the wix filters for drain intervals less than 7500miles.
Diverse ain't I?
AMSOIL Dealer
motorcraft is cheapest filter at pepboys, and i will NEVER run a fram on my car.
Starting to order K&N's from summit to run from now on.
I use Rotella in the race car we run with EMRA. My engine builder told me to use it, so I continue to do so. We broke it in with this oil. After a season of racing, I like the results and will continue to do so for the 09 season.
Brad Penn is the oil of choice for some SVRA crew chiefs I know. My engine builder also goes with Brad Penn, but for the time being I still use the Rotella only because it is easy to get. One team owner I know sent the results to a lab and it was found that Brad Penn came up the best, so they switched over and use it in everything.
Just bought some of this:
http://www.joegibbsracingoil.com/hotrod/index.html
We'll see what happens ;)
Any idea what the ZDDP PPM content is on that?
I ordered up a case of Amsoil Premium Protection 20w50 and a couple of their filters. Should be arriving today. It has over 1300ppm of ZDDP in it.
I did some simple math based on the Amsoil change interval of 15,000 miles Vs conventional oil changes at 3000 with the addition of a ZDDP additive.
Basically you're looking at $70/change with the Amsoil (figuring about $9.40/qt plus $17.95/filter) while the conventional rout will cost upwards of $140/15,000 miles (figuring $2.00/qt plus $7.00/filter plus $10.00/additives = $27/change x 5 changes)
So its going in the TC and my 360 Duster to see what happens.
5 Mopars, an S-197, and the Turbo Twinkie[SIGPIC][/SIGPIC]
The only one I could find the content on was their break in oil......2500 PPM.  I would assume it's less than that.  This is a good read:
http://www.enginebuildermag.com/Article/3100/performance_oils_and_additives_got_zinc.aspx
$17.95/filter
Any info on those Filters?
Quote from: V8Demon;245594
Ask, and ye shall receive:D
http://www.amsoil.com/storefront/eao.aspx
Cool, thanks!  Looks like the HR oil has 1600 PPM....I'm trying to confirm
**EDIT**
Actaully has 1400 PPM Zinc AND Phosphorus.  Great numbers for both.
That's quite a bit. How much is it per quart?
