Topic: Slopoke pics (Read 2242 times) previous topic - next topic
re:
Quote from: V8Demon;243625
Told ya ;)
If you're not running any type of crankcase ventilation, you're giving away power; lots of it @ high RPM's.....You running breathers or anything like that?
  Nope, just a fuel filter connected to the oil filler tube with a piece of rubber hose. It's not venting much if any at at all. The performer intake was a used piece. They broke the baffle off, along with the mounts, and plugged the pcv hole with a pipe plug. Drilling a hole in the left valve cover to fit a pcv grommet routed to an oil separator may be an option. A mechanical or electrical vacuum pump may be another option. Cost and delivery make those more difficult.
 I probably blew out the new rear main seal from that chicken $hit setup. :flame: :rollin:
