rear upper and lower control arms
im looking at getting a set of rear upper and lower control arms. i would like a solid upper set like the jegster brand, and somethink like the granatelli designed ones that i can adjust the lower spring pad height to set preload/ ride height. ive asked jegs, summit and granatelli, and they all cant give me a straight answer, will the upper and lower control arms for a fox body mustang fit under a t-bird?? also as far as the ones with heim (SP??) joints in it are those better for stuff like drag launches, and/or corner as to keep the rear end from binding as the rear end rolls or squats?? sorry im a noob and i did a few minutes of searching but couldnt find a definative anser
