Topic: Can you spot the difference? (BETTER PICS updated page 1) (Read 2700 times) previous topic - next topic
ah, i see it. it does look much better...
~John~
Yeah, after the T5 swap, we noticed she was sittin a little higher in the front.  Then the new wheels just made it way worse.  Put a set of stock 2002 Mustang GT springs in the front and lowered her just right.  The rear springs are still stock at the moment.  I'll probably keep them as-is for the time being.  I like the slight bit of rake.
I guess I didnt notice it because mines still lower than that on stock springs:rollin:
You didnt happen to go from an AOD to a T5 either, did you?
I see it now. Yeah that looks a lot better. The T5 really is a lot lighter, I think it only weighs 75 lbs. :hick:
Matt
Yeah, you're right.  All the weight that was dropped resulted in the car sitting a good bit higher than stock, and the bigger wheels just multiplied the effect.  Now with the Mustang springs, she's back where she was before the swap and wheels.
Quote from: 5.0 bird;241351
97 in a plastic crate
so around 92-95 ish pounds ;)
Quote from: kingcars;241349
no, I had the t5 stock
u also have a 4 banger
he has a 8
Quote from: fordguy545;241368
Yeah, so your springs were already set up for that weight.  Mine were set up for the AOD, hence the horrible ride height it had after the swap.  Oh well, it's fixed now!
It's Fall!
^^^^^ BEST POST EVAARRRR :rollin: :rollin: :laughing: :laughing:
Finally got some good pics; check em out guys.
Awesome. Glad ya finally updated the sig too!!! :P
blah, blah, blah. where's the new motor pics? :beatyoass:
1979 Ford Fairmont
[/B]
