Topic: what i got for $200 (Read 5746 times) previous topic - next topic
what i got for $200
Get it done?
what i got for $200
Afraid not. Only had a couple of hours to mess with it today. I would like to get it done this month. I will be painting it myself. Most likely using single-stage paint and a $25 paint gun.
1979 Ford Fairmont
[/B]
what i got for $200
What color you thinking? I like those little notchbacks if I could find one for cheap i'd buy one real quick.
what i got for $200
Ooh, I always liked that color. That should look great. What were you thinking for powertrain? 302 5-speed? I'm a fan of the old Fox four eye stangs, before everyone bought all the aerostangs that I think are boring.
what i got for $200
Nice man I wish you luck!
what i got for $200
i think i did a pretty good job. LOL!
i wanted to test my $20 paint gun, so i had a fender that was bad to test on....
needless to say, it fell over from a gust of wind after the 2nd coat.
1979 Ford Fairmont
[/B]
what i got for $200
Needs to be sanded but not too bad.
what i got for $200
Reply #39
i took the gun outta the box, set the press. to 40psi, filled the cup, and started spraying. when i finished the 2nd coat, i noticed my press. dropped to 25psi. i had never held a paint gun in my life, and will probably use this panel to learn how to use.
1979 Ford Fairmont
[/B]
what i got for $200
Reply #40
Keep an eye on air pressure it should stay pretty constant or it may bleed halfway through. But like i said it really doesnt ook that bad. Other than it needs to be mowed.:makefun:
what i got for $200
Reply #41
play with the fluid control some, lay that paint on a tad bit wetter. It'll reduce the peel a bit then wet sand it with some 1500
looks good man
