Topic: Winter Storage (Read 2412 times) previous topic - next topic
Winter Storage
Here's a little charger I had for years. made a bracket and everything. Cost something like $30
Winter Storage
mine went to sleep last Thursday dropped in a can of sea-foam and fogged the motor and on the jacks it sits. tomorrow I'll crawl under it and spray it down will WD-40
Winter Storage
The son's, daughter's, wife's and mine are all in storage. The insurance officially goes off Nov 1. Now it's back to the 94 Bird and 95 F150 everyday....
1987 Turbo Coupe - Son's car
1934 Ford - My project car
Winter Storage
mine goes into a drive in bag you close up
and put in dessicant to absorb moisture and
the up side it stays clean too.this company
made these before they made the car jacket.
i use a c. j. for another car. the both do a good job.
Winter Storage
hrrrmmmm, gonna be 68* tomorrow.....i think ill drive mine! screw storage :burnout:
Winter Storage
I'll be putting mine away soon as well.  I have never stored a car for the winter.... any tips?  Do's..  don'ts?  Mine will be inside my garage all winter.
 - Seafoam
 - battery inside or on charger
 - jack stands
 - full tank of gas
 - start if every so often
===85BIRD===
:birdsmily:
Winter Storage
Quote from: gumby;240974
Yeah it's supposed to be that warm tomorrow here too but I already suspended the insurance till April on mine:hick:
Since I can't drive it I'll be using tomorrow to cut the lawn one last time and pull out the garden. Fun stuff for Halloween :pbb:
Winter Storage
Quote from: 85bird;240986
 - Seafoam
 - jack stands
 - full tank of gas
I do all that except I put Stabil in the tank instead of Seafoam. Also I don't put the car on jack stands as I've never had a problem with the wheels flat spotting. I do roll the car once every couple of weeks when I start it so a new part of the tire is taking the weight of the car. One thing to remember is to change the oil right after you bring it out in the spring. The oil gets pretty sucky sitting all winter.
Winter Storage
 - Seafoam
 - jack stands
 - full tank of gas
Bounce fabric softeners in the glove box, floor seats, trunk, under hood, etc...  Rumor is it keeps mice away, can't prove it, but it's cheap insurance.
1987 TC
Winter Storage
I usually park mine in the garage around January when we get a bad frost, i HATE having to se frost off the windshield in january...and once i had to do it in February... global warming.
Winter Storage
 - Seafoam
 - jack stands
 - full tank of gas
 -plastic sheeting for the floor
 - WD-40 for the bottom of the car
 -fogging oil  with this you do not have to start the car every so often
-car cover
Winter Storage
Quote from: blknredcougar;241106
Ive never heard of this, give me a little info on this.(fogging oil)
On a side note, it is in the upper 70's here all weekend and very sunny and all the trees are beautiful and full leaves yet.  It is truely a perfect time of year.  I will be cruising in the Cat this weekend.
Mike
Winter Storage
THe fogging oil has rust inhibateor(sp). They use it in marine engines
for storage.
 I heard  moth balls or bounce sheets. Mice don't like the smell of
the moth balls or bounce sheets.
