Topic: I need a set of cruise control buttons with the wiring intact... (Read 1233 times) previous topic - next topic
They will be used as cruise switches.Wait til I finish,you'll see.
As far as the rear,the spare I have came from a driver that was smacked and bent the core support and then parted out.It was a good one.I need to swap mine asap because I have a dyno test Friday for the Sport.2 pulls for $10.00  (If I get the rear swapped and make it there,results soon after).I can have the rear that's being pulled checked later.It'll be in the garage until then.I'll pick up the new diff fluid and friction modifier,bearings and seals,tomorrow,and by friday afternoon should have it all done.I'll post pics if possible.
