Topic: 1986 cougar xr-7 2.3turbo a.c. (Read 1530 times) previous topic - next topic
have a little leak in the body of a.c. compess- the dye shows  it- any info,stop leak  info-anything-
Does leak till empty? Iv'e seen them leak when overfilled there.
1986 cougar 2.3 a.c.
it does leak till empty.fill it two times over four months.maybe filled to much ,both times?
In the body of the compressor sounds like time for another one. There is stuff out there supposed to seal up any AC leak. I do believe the one with a grantee it is Red Angle ac stop leak you might try that. Also I know there is a pressure relief valve on the rear of the compressor. Here is a link to the 1st page I found with it listed. http://www.autobarn.net/red-angel.html
Ps you might also take your compressor off and take to a welding shop and see if they could weld it up. You might want to teat it apart first!
