Topic: so, i picked up another FREE 351w..... (Read 2310 times) previous topic - next topic
Quote from: Haystack;259126
I really do hate you. You might as well go 408 for the same price.
if i go with a 393, i can still use my rods. that'll save a few hundred bucks. and honestly i dont see that much gain from 15 extra cubes.
1979 Ford Fairmont
[/B]
Sweet i scored my 351 for $100 out of f-150. I tore it down and its all fresh not to long ago. still see cross hatches. I installed headgaskets,roller conversion 5.0, now will go in my 88hatch when all said n done. But free is way better!!!! good luck on your project.
1999 Trailblazer(wifes rig)
im waiting to get my heads back from the machine shop, so i decided to assemble the shortblock. i was given one pair of used rod bearings on accident, so ill be getting that swapped out later today. (that's why only seven pistons are installed)
1979 Ford Fairmont
[/B]
Nice, I'll be starting my motor rebuild soon, this just makes me want to get going that much more.
the last piston is in, and ill have my heads back today. the shop had to shave .030" off! i asked them to CC them, since that's a significant jump in compression. ill have pics later today.
1979 Ford Fairmont
[/B]
got the heads back on Friday. they were milled .030" to 58cc, new 2.02"/1.60" Manley valves, new Comp Cam 10 degree locks, new Comp Cams spring cups, and a 5-angle valve job was done. i dont know the brand of the springs, but they have 115# closed seat pressure, and are good up to .600" lift. :D
1979 Ford Fairmont
[/B]
2 more before i painted the block bronze.....
1979 Ford Fairmont
[/B]
OH NO!!!! Fram filter! :beatyoass:
Just kidding.
a little closer....
1979 Ford Fairmont
[/B]
