Topic: Friggin Frusterating Fluids (Read 3307 times) previous topic - next topic
pennzoil has a multi vehicle atf. good for everything from
from dexron 2 through mercon 5. not for type F.
good for ford and gm and some chryslers. cant be used
as mercon 6 which i believe is a full synthetic..
m-v atf is a semi synthetic. even has an allison
and cat trans rating. i have it in all my vehicle plus
an additive. have never had a trans problem.
I have the original type H fluid that came in my 84 C5 trans and have never had any problems.
If the Haynes book is accurate, and it looks like it's turning out to be, Type H is used in the manual trannys, not the autos.
Operation: X Marks the Spot
5.0L SEFI, AOD, 8.8" 3.02 TracLok - All Stock
Quote from: cougarXLS;237274
I was just pointing out that my 84 T-bird ,that I bought new, has never had the transmission fluid changed. The C3 and AOD came with Dexron II. The C5 (three speed automatic) came with Type H.
The shop manual says: Fluid used with C5 automatic transmission contains a detergent that retains particles in suspension that are gererated during normal transmission use.
Type H is no longer available. Don't know if it was used in any manuals. In 84 the T5 used Dexron II Series D (whatever that is).
Learn something new everyday.  Thanks softtouch.
Now, because I already learned something new today, does this mean I still have to go to class?  :hick:
lol
