Topic: Very rich fuel mix (Read 2787 times) previous topic - next topic
Re: Very rich fuel mix
I really appreciate the info...this will help a lot. Also helped me know what the spout is after reading so much about it. I don't claim much experience or knowledge when working with cars but this has been interesting.
I will most likely not get much opportunity to dig in until the weekend, busy week, but looking forward to it and making sure I know what I need to do.
Quote from: Paul Flockhart
Hey Amooset,  Yougot that 5.0 CFI on? how's it runnin?
Yay for thread hijacking!  :giggle:
You bet I did.  I had to hack away at the choke mount on the v8 TB because it interferred with the egr plate, but other than that it was pretty easy.  Basically what I did was swap out the bottom part of the throttle body and put the original top part (w/ injectors and pressure regulator) back on.  There is a lot better acceleration through the mid range.  Before there used to be kind of a dead spot in the middle.  It actually runs like I think it should have run from the factory.  It runs better at WOT than it used to.  The peak performance used to happen at about 3/4 throttle and then it would just drop off if you floored it.  A definate must-do swap for anyone.
1987 Thunderbird 3.8. Sold :(
