Re: Very rich fuel mix
Reply #3 –
ok when u did that tune up did u change the o2 sensor? if not and its origional maybe that could cause your bad fuel milage. also your fpr could of gone bad on you. when the car is running pull the vaspoogee line off the fpr if its wet with gas then replace the fpr. and definatly that o2 sensor if u havent already. that will help with gas milage.
