Topic: Considering buying '87 Turbo Coupe (Read 10078 times) previous topic - next topic
It's really in nice shape. It doesn't look as if there's any rust on it either
Quote from: daminc;236161
There i some rust in lower parts of the body - not a big holes, except lower driver side fender. It doesnt look that good underneath, but still no see thru holes.
If you wanna hear how the rusted exhaust sounds and how it revvs up here's a short video: http://www.youtube.com/watch?v=gMYCG1EQsVo
Quote from: Shevretti;236160
I always thought 302 is the thing?
Depends on who you ask....  :burnout: :rollin:
The sensor will be a bunch easier to change if you remove the upper intake, but with swivel socket, can be done with it in place... Before you change anything, scan the computer and see if there is a code for it...
I noticed today, that there's one thing wrong under the hood. There isn't any vacuum line going to MAP sensor. How come engine runs good? BTW.What's the routing of the vacuum line to the MAP? Maybe it's sill hanging somewhere around?
I have to read codes, but it started to rain here so badly that it's not fun to work on cars :( And it's gonna stay this way for a week or so :(
Quote from: Shevretti;236289
Not supposed to be one, on a TC its used as a BAP(barometric pressure) sensor... Same deal on a Mass Air 5.0 setup...
Hey Mariusz try a Bobs header and a I don't remiber what the name of the company is but its like striner or something like that.  If anyone knows there website let me know too.
Quote from: 88TurboCoupeman01;236373
First I have to spend some $$$ on front and rear brake pads, new spark lugs, cables, fixing up the turbo etc. Will think about some performance stuff next year :)
Just a quick TC related question... can I put base T-bird 14'' rims on the TC or maybe the rotors are too big? There are matal wires almost coming out from of the front tires and I need good tires to pass inspection, so I wanted to use a winter set from the 3.8 temoprarly.
the 87 - 88 TC would require 15 inch or more rims
I believe 15" is the smallest that will fit over the front rotors, the 14'' will fit the rear...
Yeah, and some very early ten hole, and turbines won't clear 16" either...there's a number or code cast into the inside of the wheel, but I don't remember what it is...it was a date code, I think '87 and newer wheels will work...I personally had turbines on my TC...I can look at them in the daylight, and let you know...
Yeah, and some very early ten hole, and turbines won't clear either...there's a number or code cast into the inside of the wheel, but I don't remember what it is...it was a date code, I think '87 and newer wheels will work...I personally had turbines on my TC...I can look at them in the daylight, and let you know...
Thanks for the info! Wish it was that easy to get a spare set of ten hole or turbines here :D All I can get easily here with 4x108 bolt pattern are eg. Focus rims but I guess they have wrong offset?
What's the correct offset range for the T-bird? I think Focus 15'' rims have ET around 42-44.
Congrats on your 87 TC purchase.
I have been playing with these cars since 1992 and still like playing with them !
I still get excited when I see one for sale. I have to check it out even if I don't have the room to bring it home.
83 T-Bird 460
83 T-Bird Heritage 5.0
84 T-Bird 5.0
87 T-Bird Turbo Coupe
88 Bronco II Drag truck 302
95 Mustang GT auto
2004 F-350 CC Dually V-10
Congrats on the purchase! It looks good! You shouldn't have to remove the intake for the fan switch. Someone mentioned a switch between injectors, but isn't there another switch in the lower intake? That was one I swapped out...I also had to flush the water jackets--there was so much gunk in there that it was preventing the sensor from sensing the temperature properly...
