Topic: twin turbo 5.oh (Read 2316 times) previous topic - next topic
twin turbo 5.oh
ok, while yes, i do have my parts list ready for when i have benjamins, i'm still looking at ideas.  twin turbo 5.0's. what can you guys tell me. anyone running such setup? anyone know of any kits? etc etc.  knowledge is power, and i like climbing the ladder of power.
Quote from: ?;247173
Screw you Ford... I'm going to get a ranger riding a mustang to restore your focus on the expedition needed to escape from the edge of bankruptcy.
Quote from: random im message;385099
need to pretend to get some awesome wheels for my invisible cars so i can pimp hard in my dreams at night...
twin turbo 5.oh
Andrew Beedle has it,can see pic of it here.
http://www.foxtbirdcougarforums.com/showthread.php?t=20502
twin turbo 5.oh
greg, (5.8Lfastcat) has a TT351W in his cat....
twin turbo 5.oh
Soooooo, you want twin turbos why?  And how many benjamins?
Not sayin' 'no', just askin' why.  A good place to start is Maximum Boost by Corky Bell.
__________________
Twin '85 TCs
White/ Grey 2-tone
twin turbo 5.oh
Here you go. budjet junkyard set up, and propperly set up.
http://toohighpsi.com/
twin turbo 5.oh
Quote from: 1WLD BRD;235592
Really?  I was under the impression it was a single T70.
twin turbo 5.oh
Quote from: tc²;235639
I thought he only had one also
twin turbo 5.oh
i wouldt know, thats why i'm asking :D
on a more serious note, i'd be looking to do a budget build.  twin turbo carbureted would be awesome, but it would also be wicked cool to do this to a cfi setup.....and i just so happen to have...a cfi setup.
DISCUSS!!! :D
twin turbo 5.oh
haha no... his old cougar is a single.. this one is a twin....  I have pics of them if you wanna see them....
twin turbo 5.oh
turbo and budget dont realy play all that nicely together.......
~John~
twin turbo 5.oh
1) Garrett says there are three times one should consider using multiple superchargers.  Good info: http://www.turbobygarrett.com/
2) I'm not really sure why anyone would consider running a carburetor with a turbo these days but some people do.  It's not hard to find everything you need for EFI these days.
3) If I were to budget build a TT SBF, the menu would include a couple of TC turbos (either T3s or IHIs depending), forged pistons, one large or two small ICs, and EFI.
__________________
Twin '85 TCs
White/ Grey 2-tone
twin turbo 5.oh
hmmm.....i had an interesting idea.
does anyone know the cfm rating and injector sizes in cfi units?
from what i've heard, they use a pair of 42lb injectors in a regular cfi.  i was thinking a dual 4bbl manifold with a pair of cfi's on 2bbl-to-4bbl adapters, and a turbo to each cfi.
i understand that the biggest problems with a standard cfi is the manifold, so swap manifolds and go from there.
Thoughts?
twin turbo 5.oh
The biggest problem would be finding a computer to run the thing... Maybe you could run it on one CFI unit and rig a relay to to connect the second CFI under boost... Likely it would be far from optimum, and probably would not supply fuel for more than 5-6 PSI...
BTW the HO CFI used 52lb injectors, std 5.0 46lb, and 3.8 37lb...
twin turbo 5.oh
42 lbs injectors, PMAS blow thru tube calibrated for 42#er's, stock eec, locked timing (spout out), 8 psi, intercooler.  This simple setup should be good to 400+ hp on a stock block, assuming you don't lean out and split the block in two.  Get a good wideband O2 kit with data logging abilities!
I had my entire kit together and was ready to cut my pipes but changed routes.  I have a lot of info if you have questions...  also have a bunch of stuff for sale (injectors, IC, cheapy turbos, wideband kit, boost gauge, BOV's, mandrel bends, header s, 5.0 TT headers, etc...)
1988 Thunderbird Turbo Coupe
twin turbo 5.oh
booksix....you might just become my new best friend :D
