Topic: Truck Questions (Read 1078 times) previous topic - next topic
Truck Questions
So its hard to find a good forum like this one, or a good site like CoolCats that is filled with info and experianced people.
I bought a Mazda B2200 2 weeks ago and it had a starting problem that seemed to just be an old weak battery since we could jump it no problem.
After i started messing wioth it I noticed the crank pulley was wobbling. No idea how or what caused it but i swapped the pullet and it is not the pulley. So now I am thinking its the crank. I dont want to rebuild it really.
My options are
Sell it and just cut even
Drive it til it breaks
Swap motors
rebuild it
I need to know what you guys think might cause the wobble. Im sure its the crank though.
I need to know if anyone knows what motors will drop in. I think but not sure about all of them but some Probe motors, 626s, 323s
Any info is good. Its a new world under there, Im missing mare than half a motor.
Truck Questions
This is what he said today;
Dillon, here's what I have learned today:
Dan (of Dan's Foreign Car Repair) said that it is not unusual for a
crankshaft pulley to have a slight wobble. Apparently, the pulleys on most
of the new import and smaller domestic engines have an elastomer (rubber
ring) incorporated into the pulley making them look similar to a harmonic
damper;  my understanding is that this rubber ring may account for some
slight wobble.
He also said that any crankshaft pulley obtained from a salvage yard could
be expected to have the same wobble.  Part of the problem is that a puller
must be used to remove the pulley, and one must be extremely careful in
using the puller, as tightening too much one one side can slightly deform
the shape of the pulley.
I also talked with a mechanic friend of mine who said that (with rare
exception) it is not possible to bend a crankshaft--they will break.  That
is because most crankshafts today are not made of steel--they are cast (not
cast iron, but an alloy very similar).  The exceptions are volkswagons and
high-performance high-speed engines.  He also noted that one should not
hammer a pulley on to the crankshaft, because of the possibility of causing
a fracture in the crankshaft.  The pulley should be pulled onto the
crankshaft using the center bolt.
Both mechanics said that if the wobble is slight, it won't cause any
problem and is not something to worry about.  My mechanic friend raised the
hood of his own car to show me that his crankshaft pulley had about 1/16
movement (wobble).  He said that if the wobble is more than 1/8 inch, then
it should be replaced.  An OEM pulley is okay in most cases.
Also, the alternator should charge if the tension in the belt is adjusted
correctly.
I hope this helps, and am interested in what your mechanics have to say.
Truck Questions
First off, what year is the little Mazda?
Second off, it's basically the same thing as a Ford Ranger, especially if it's from say, 89 or newer.
Does it have the 2.3/2.5 four, or is it the V6?
(BTW, no probe/626 engine will fit w/o mods...)
And I've never heard of the crank pulley being "allowed" a measurement of wobble...to my thinking, that'd cause some vibration.
oh yeah... www.ford-trucks.com has a Ranger/B2000 sub-forum, but beware, they're really fawking political over there, I havn't signed in in like a year now..:hick:
Good luck, and let me know whatya find man.
Truck Questions
Beau, a B2200 has the Mazda 2.2 liter engine in it, not a Ford engine. The 93 and older Mazdas were really Mazdas, not rebadged Rangers (and oddly enough, the pre-82 Courier was a rebadged Mazda truck).
I'd drive it until it broke. I'd also try to find another one somewhere liek a used car lot and look at the pulley to see if it's wobbling on that one too...
Truck Questions
ahhh, guess I was mistaken in my info then, my bad.
Sorry Dillon...the link to FTE is correct tho, lol.
Truck Questions
Quote from: FordTruckFreeek;235500
The wobble is pretty bad. Some times I could push the belt and there would be a good amount of play, anout an inch or so but other times it would be tight. A little wobble wouldnt bother me but the fact the belt was that lose did. I dont want to hit 4 grand and the little belt fly off.
The timing needs adjusted, I think Im going to throw a new battery in it, I need to see if the belt play is as bad with the new pulley or better.
For the record, I did use a puller and it slid right off no abuse. I tapped it with a ball pin hammer lightly but no real force.
It would be a fun little truck if I could get it right.
